  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
what a farking busy day I had....
actually busy month!
1 some low life keyed my car!! :D
2 Bird shit on me arm b4 I went to uni ! so I had to shower againeeewwwwwww.!
3 my ex is graduating and I should least buy her flowers but I got no $$$$ :(
4 rent is 2wks behind!
5 I have to do two more lab to write up!
6 midterm test is on in two weeks
man I am going carzy!
Niz - are you still going to be on the same floor and same dept?
Joe - It's a FRICKIN EX MAN!! I don't buy nothing for ex's.... hence the reason why they are called ex's!....
maybe it's just me but it is really hard for me to stay friends with ex's..........:D
Looks like Nizmo is a spoilt monkey.... i think the only think i get off my ex's are dirty looks....
For the record i have NEVER cheated on a girl in my whole life! I just find it hard to be friend with an ex as one side most often has more feeling than the other.....
Originally posted by GTS-t VSPEC
25GTT,
How did your suspension work out?
See'ya:burnout:
Jash @ C-red has let me borrow and has fitted some coilovers whilst my JIC's get sent over to queensland to get fixed.
All fingers are crossed that they are fixed up ok. So we are half way through of the suspension saga.... does feel nice to have working suspension again and not bounce around for half an hour after each bump :-)
Hi everyone. I'm back. Niz, I'm glad things have worked out for you in the job department. I know exactly how you feel, I have been looking for work for months. Bank husband is threatening to issue bank statements. I may have overdrawn that account.
I do have a job, it's just that I want something more. Hope every one else is having a good day.
haha well i also score a squeeze on the butt when the new chickies not around from him too haha yeah i got floor matts, subs, amps and this was after we broke up. When we were together he payed for new suspension to be done to the ZX - from his dodgy mates of coarse haha.
No Daniel be on floor 9 mate :D Under Simon Johnsons team.
    • That is correct. I'm using a modified ABS ring and a ZF speed sensor on my rear diff for speed input. I'm running a Haltech ecu.
    • Been busy with the newborn. We originally thought we were going to go for a third, but we're good with two lol. He's starting to actually sleep now so I've had some energy to work on the car. It's been parked away in the garage since late November due to winter.  I went ahead and redid all my head oil drains. I originally had my front and rear head drain going into the same pipe but have since split them up. I also added an Ethanol content sensor to get ready to run E85 this summer. Tossed it on my return line. Sensor sits nicely under my intake manifold.    I also have a lot of parts that came in for my rear end. I'll be swapping over to a 3.3 final drive and doing the GK teck anti squat mod. While the rear subframe is off, I'll also change every bushing. We're planning on buying another house soon with the condition that I get at a minimum a 2 door garage, so I'll wait to have more room for this. Now onto the strange things that recently happened... After changing the lower rad hose (It had been sitting in my cabinet for well over a year and was the last hose I had to replace), I let the car idle in the garage to bleed my coolant. After running for a few minutes, it started missing. Got much worst within a minute or two and then stalled and would not restart. My crank sensor decided to crap itself. No damage, no explanation, just died. I went ahead and replaced it with another ZF sensor but the heavier duty stainless model with a shield. Tossed that in and started right up. Has anyone else seen this? I hate when things fail without cause. Luckily this was a blessing in disguise... This lead me to recheck my timing. It seems I may have had a beer or two the last time I had set my TDC angle as I was off exactly 5 degrees... I miscounted a line haha. I was running 5 degrees less then commanded. It's a little embarrassing but helps explain why my dyno operator seemed to think I should be making more then 478rwkws.
    • Sharing results from recent Liberty Walk R35 GTR, since they are still considered as somesort of a V36 Skyline. We do them turbos too. This are high flowed SS-1 models with ball bearing conversion done.  Car have managed to pull 485awkws @ 20Psi so far pushing limitations of factory built engine. The build list for R35 GTR enthusiasts as follow : HyperGear high flowed stock turbos in SS1 (G25-660 specs) Custom titanium intake pipes. Vspec performance titanium front pipes. Vspec performance 4" titanium exhaust. Upgrade fuel pumps. 1200cc injectors. Ignition coilpacks Hks intake plenum. Hks intercooler piping. Greddy intercooler. Greddy bovs. Top-secret coolant reservoir. Emtron ecu. Straight E85. Built gear box.
    • Nah no bearings, just slip fit.  Would be a reasonably challenging but not impossible job to modify it to run bearings but I'm hoping that's not necessary as I may have well built one myself if I end up spending hours modifying it!
    • Brumbys with good shells are bloody expensive, I've looked at 2 "cheaper" cars, and walked away from both,  plus after some research spare parts are fairly sparce I'm starting to think that I missed the boat on finding a clean one that is straight (ish) and without alot rust I'm starting to think about a old Hilux as panels and other parts are much more available as they sold tens of thousands of them I use to be indecisive but now I'm not sure
