  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
Of course I can:D
First of all have you tried Brasso? That will clean the outside of the lens very well. If you need to do the inside then you will need to remove the entire light essembly (not easy) and then break the seal on the lens in order to clean it. You then need to ensure a water tight seal to prevent moisture from getting in.
I have a number of people who do it properly if you want. I just clean the outside, and it looks good.
See'ya:burnout:
You can get Brasso from most supermarkets/hardware stores. Usually used for cleaning metal. You need to apply ii and rub it in, allow ito to dry for 30sec or so, then polish it off with some elbow grease. Works very well. Dont get it on the paintwork.
See'ya:burnout:
