  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
YOu should see the apartemtns that i live at!! man it's like melrose place!!!
There is a divorce going on directly under us! then the people under that 3 guys just moved in and one of the room mates slept with the other room mates sister but was too scared to tell him! no joke that all happened in one weekend... stay tuned next week for an update on "the Joondalup Days of our lives"
Originally posted by GTS-t VSPEC
Cool, can you take video footage, so we can see what the characters looks like?
See'ya:burnout:
the divorce couple aint that good there about 60 so i will let your imagination run rampant there thinking about naked 60 year old's having love tantrums!:uh-huh:
However well the sister was quite attractive!
I will have to invite your self and some of the lads plus nizmo around in a few weeks time! BBQ next to the pool plus a heated spa is always sweeeeet!!!
Promises, promises:p
Will you be able to make the cruise on the 23rd?
See'ya:burnout:
I will have to give you my camera for the cruise then Paul if Nizmo goes!! to she if she is true to her words take some pics for the lads! ahaah!:bahaha:
    • Anything above ~9.5V is acceptable. The higher the better, but it will almost always drop to at least 10.5V, if not lower, even with a new big battery and everything else being good. 9.76 is not a concern. If it goes below 9, you'd be sure that there's a problem with either the battery or the connections.
    • It's new almost. Under a year old i think and I've tested it twice at supercheap
    • Glue the head from a Pez dispenser on it. Goofy, or Winnie the Pooh, so something.
    • Adjusting the idle screw is usually (emphasis on usually) just covering up deeper issues. Stuff like the cold start valve not closing properly. Throttle shaft seals on the way out. Coolant temp sensors getting out of spec. Coolant temp sensors especially can be a bear to diagnose because they can fail subtly. My dad just spent weeks chasing down his high idle. He cleaned the coolant temp sensor and everything but the resistance curve just drifts over time and if it's been 20+ years they also get super slow to respond as well. Has a massive effect on fuel economy as if it's off the ECU is going to run richer and command high idle for far longer than it should otherwise.
    • How old is the battery, it's more likely your battery is on its way out.
