  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
Originally posted by skyzerr33
paul and brett u can keep guessing
my plates are ordered and on there way
u'll never get it
Yoda
Wookie
Skywalker
Luke4Eva
Starwars
HansSolo
Lightsaber
It'll be something to do with Star Wars.
my mum makes the best pasties (yes she cooked for once *shock horror*) So we had yummy pasties tonight.
I make the best casoroles - proper beef n red wine ones not that packet shite! - they are so yummy in winter!
Sneeza
Haven't seen you post for at least..........hmm.
bout a 100 pages of this garbage.
Hows the car or is this something we don't ask.
BTW , I have come to the conclusion that Niz does very little and pwptf does NO work during the day.
Geez you two can whore !!:(
Takes me 1/2 hr each night just to catch up on this Days of our lives thread.
Cheers
Ken
Joe - its a database type program I think - like mulitmedia databases. I think. It stores everything in a database. Its like a softwarre suite (like MS office) that has a web builder and stuff. Don;t know what programs - its all web stuff. I assume it would support java
Joe - here you go
ColdFusion has its own page markup language, called ColdFusion Markup Language (CFML). CFML encompasses the Web's Hypertext Markup Language (HTML) and Extensible Markup Language (XML). A just-in-time (JIT) compiler turns the CFML into the pages that get served. Allaire emphasizes that their product set is open and "extensible". Applications can access databases using Microsoft's OLE DB, Open Database Connectivity (ODBC), or drivers that access Oracle and Sybase databases. ColdFusion can be coordinated with distributed applications that use Common Object Request Broker Architecture (CORBA) or Microsoft's Distributed Component Object Model (DCOM) to interact with other network applications.
    • Depends how low and tyre size. Should fit with natural camber, skinny tyres and rolled guards.
    • Hi guys, planning to get 18x9 +25 in fronts and 18x10 +25 in rears been reading the whole thread and cant really find anything   Anyone know if these will fit a r34 gtt with no scrubbing or guard work needed?
    • They usually get made by hand as part of any such swap.
    • Was planning on getting an R35 MAF and the adapter, should this be okay? Also any idea where I could get my hands on an intake pipe?
    • I mean yes, if you're starting from scratch on an unknown engine yes you don't need to be doing all kinds of math in the background but if you're doing relatively minor changes like AFM + injectors + boost up with some aftermarket turbos it takes quite a bit of math if you want to do something like maintain OEM fuel + timing tables but compressed and then a bit more load scale up top. I think I've spent too much time working on big engineering nightmares though so I'm a big fan of trying to constrain the scope of whatever work I'm doing as much as possible and trying to get it right before moving on. For example, a local owner just did the usual E85 + single turbo conversion to his R32 GTR and nearly burned his car to the ground doing some spirited driving up the local mountains. Turbine is unshielded and too close to the hood insulation. It's tough to balance "just get the project done" and "seemingly small details can cause massive setbacks I'm not willing to deal with".
