  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
not yet. the head has to come off for inspection of the valves and thats a fairly big job. am trying to rally together a team of mechanics to do it in the garage at home cos i havent got enough money to pay a workshop to do it. will have to take it from there, hopefully its just a valve which needs replacing in which case i should be able to get it fixed fairly cheaply. theres just alot of labour involved thats all
yes im torn between wanting the best for my car and being a tightarse cos i cant afford the best for my car.
But i learnt from the ZX - mates rates are not a good thing! specially with these kinds of cars - its good if u have mates that actually know what they are doing instead of mates that have worked on everything but an import. hehe so im determined to do it right this time even if i have to save doubley hard to get what i want in the bloomin thing!
i find it more expensive to fix other peoples mistakes haha e.g took ZX to service dept working fine but with fuel smell 3 weeks later pick it up because they had pulled it apart and did nothing with it - car barely worked just got it to another dept 20mins away. hmmm then it took $700 to fix the other depts mistakes and get it working again. refused to pay the other dept.
they were so lazy putting it back together that some of the bolts from the manifold were left under the windscreen wipers. Nissan workshop but not one that deals with imports - dont think they had a friggin clue what they were looking at - in that case they should of told me before they proceeded to pull it apart. Then they tried to hit me up for $250 worth of labour i just was a wreck at that time so my ex sorted them out and went absolutely sick at the guy - classic. we didnt pay it luckily just the $700 to fix the mess.
yeh well me macka shannon and paul are all going to attack it this weekend. along with tristan a guy i know from work whos rebuilt his RB25 and various other engines and knows his shit. fingers crossed it comes together alright
i prefer doing it myself, that way if anything goes wrong theres no-one else to blame but yourself. and if you take your time doing it its easy to do a professional job
    • In all the track days I've done over the past few months I've only had 1 issue with braking and thats with my current EBC pads (can't remember the colour, but they're not a track pad). I don't *think* I have had issues with brake fluid getting too hot, my understanding is that when that happens you will have quite noticeable brake loss - which I haven't had.  I'm using just regular ol' Penrite Super DOT4 fluid. I use this fluid in everything and my cars always seem to stop so I see no reason to change, except ... for the 335i. I need to do a fluid flush and was thinking about my fluid of choice and wondering if I should consider using something more high temp? Its not a super fast car by any standards but I'd hate to do a flush and then find myself with no brakes when I get. to Wakefield.  I guess, my question can be summed up as "How fast do you need to be driving to need higher temp brake fluid?"  I remember high temp fluid was considered a must have back in the day when I had my GTR.
    • For anyone that comes here looking for answers on what can go wrong with gts-4 to rb25detneo swap. The Gloria's awd sump is different and does not fit. The rb25neo from stagea are exactly the same sump bolt pattern and axel alignment. Castings numbers are different on Gloria's blocks and oilpans if they need to be identified.
    • I have information on this for anyone that comes looking again. https://www.facebook.com/share/p/18gsbFaYTU/ The rb25det neo from the stagea has the same sumo as rb26 and r32 gts4 (and other awd models). The sump that has caused so many problems during swaps are from the awd neo Gloria's. The casting numbers on the block and oil pans are different so this may help identify if you can't confirm where the motor came from
    • Not feasible to fix the boot lid you had? Damage looked minor/hard to even see :p Source: Drove into something recently and you should be happy you didn't!
    • Another new used boot arrived at the painters, it was sent back as there was nearly as much damage as the original one I want to replace  Finding a clean used boot lid is proving problematic, and I'm not keen on dropping $1500 on a new one from Mazda Sigh....
