  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
oh yeh i am now driving the corrolla '84 rwd.
this thing rulz m8, faster than the jeep ive been driving plus it it nicer to drive. If it had aircon and a radio it would have it beat. oh yeh and if the muffler wasnt fudged from last time i mounted a curb and also when a moron drove up the back of it.
Open bonnet an rust is sprayed every where, i figure this is because of the missing radiator cap. Rego is expired last month.
Oil is still full and even with no rad cap it didnt overheat!!!
Originally posted by MrGTST
Yeah aint that true Kym.... Especially the part where she just turned up in her underwear!!! Boy that turned some heads... :P
dam straight mate.... good thing we had those cans of cream to cover her skin before any perverts strolled by eh?
p.s. nice to put a face to the name, and meet you Brett!
    • Here is the before and after of the scraping/sanding of the IC pads on the tachometer board for the fix mentioned in this thread. And yes it worked fine after. Just a note if you change any components on the board the tach calibration can be wrong showing the wrong idle etc...only problem is once it is installed back in the cluster you can't get to it to adjust...ouch! My fix was to cut out the calibration pot (the blue one) from the board and run it with two wires to the fuse panel under the dash where I could adjust the idle calibration once everything was installed. And yes I soldered everything up again including the half soldered components either side of the IC in my photos
    • After an excellent condition, working! oem radio for a 97 r33 And the steering wheel shroud/cover as mines a little bit scratched up Am in Melbourne
    • So my exhaust is loud and sounds awesome (good thing) but also is very loud when coming and going, dont want to piss off the neighours etc Are the varex adjustable mufflers any good? I contacted them but they dont make r33 specific exhausts Ive also see the adjustable inlets on this site but apparently they might restrict airflow too much which wouldnt be good for the engine. Would prefer something thats adjustable from in cabin so i can change it on the fly, dont really want to put in one of those permanent exhaust tip things.  Any other recommendations would be appreciated!
    • You don't need to lean as far to pour the oil in, or change the spark plugs either 😛
    • Indeed, it is much easier to get at the filter with the engine on a stand
