  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
Originally posted by Nizmo
shitt thats right will n grace is on - i withdraw my previous remark -  damn i was going to watch that.
well I never !!
You would rather watch some crap American in your face , unsubtle , done to death humour than stay on here and have an intellectual discussion about your voyeuristic sex life:D
Hmmm..... on second thoughts , don't answer that.
Cheers
old wine
Ken
voyeuristic sex life? - im a doer not a watcher ken haha.
If u've read previous posts i think you've got enough bad images to last u the rest of ya lifetime - I'll let u have a rest tonight haha Its all Pauls fault he's a bad influence on me (gotta blame the person thats not here to defend themself) :D
I'm a doer and a watcher .lol
What it meant is your sex life and discussions have been up for public scrutiny on these forums for the last...........oh .......200pages.
And stop trying to boost your post count while pwpt60secf is not here to retaliate.:D
Cheers
ken
Originally posted by Sneeza
anyway guys - gotta go .
OHHH SH*TTTTT I left the sprinklers on for like an hour ARRGGHHHHH my dam is going to be DRY!
bye guys!
Dam ???
as in Mundaring dam ??
damn they must be big sprinklers.
Cheers
Ken
my sex life hasnt been up for discussion - i see no recollection on spillin the beans about anything to do with.
Just a few suggestive playful comments being tossed aroung :D
You expect us to work during 9 -5 geez!
In pwpt60secf case ,that isn't the only thing being tossed.:D
Page ownage to the the Niz , the biatch. Damn , missed again:D
Cheers
Ken
    • What can't be done with a little bit of decking board or similar timber bolted to a hub flange via 2 wheel nuts is not worth talking about.
    • I noticed something. On the tps sensor and the sensor behind the adjustment screw is adjusted towards the far left. Are these screws supposed to be centered? (this sensor was in the same position before the tune as well)  Also attached a photo of where my car usually idles at when warm (sometimes a tiny bit above that). I think I might have screwed up the calculation and it might have better than I thought lol at 750rpm still not 650rpm though.
    • So for both general interest of engine health, and to rule out any coolant/oil issues, I organised an oil analysis done on the 125,000klm oil Results below, all good, just a bit of fuel dilution which I'm not too worried about
    • This is actually a really good way of measuring what wheels fit. If only there was a similar measurement between hub face and suspension :p That said, it's probably pretty simple to actually measure it all with the wheel off the car for the rear. The front is a bit more complex but..
    • Being the top Google search result for R34 wheel-related inquiries, lemme throw down my experience. I calculated that 100mm from hub face to wheel face is about the perfect fitment for my ENR34 sedan.  I've been running 18x8.5s, ET35, with a 1" spacer. So, 8.5in to mm = 216mm. 216/2 = 108mm. 108-35 = 73mm. 73+ 25 (1" to mm) = 98mm.  If you wanna get close to this on dif widths, here are the offsets you'll want: 9" - ET around 15mm 9.5" - ET around 20mm 10" - you're crazy, but ET around 30mm All these should fit perfectly on a non-widebody, non-GTR Skyline. Note that it's probably the absolute max, and you're probably better off running a couple degrees of camber in this config, but it looks great, super flush.
