  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
some veilside kits are awesome. Cars always look good in black just a pity its such a difficult colour maintenance wise.
Shuto-boy are you the one that was the meat in the sandwhich at the last cruise. If so hope your car is coming back together nicely!
nah dark not desperate - sure he would like to pick his own girl.
I loved your nismo top shuto-boy haha my parents have all these holden clothing etc need to even the balance in this house!
Yes i saw EvilR33 on the way back from dragwars - tried to drag me but my cars not mechanically up to scratch at the moment and he could kick my ass so no sense embarassing myself.
do like the colour of evils car.
I like the metallic blue but they usually come in two toned form which is yuk - two toned cars are a little bit - what were they thinking? My apologies to anyone with a two toned car that just saw that comment.
    • A bit late but A disk S13P fit over stock R32 GTR brakes, usually A disk front, O disk rear works.
    • Or, the height of the release bearing is not correct for your combo. Start with the bleeding and checking the slave moves throughout its range when you press the pedal (2 person required), but it is possible for the height to be internally wrong too (box back off to measure.
    • Yes, there's quite a few things that can go wrong during a clutch install. Very unlikely. I have a similar clutch. They (ACS) make good gear. No, it is not normal. It is possible that you just need to bleed the clutch slave. But the new clutch will also have a more aggressive actuation force/pressure, and so your old slave cylinder might be a bit leaky or otherwise compromised, and not up to the extra force required. Or the master cylinder, same.
    • Hi...so a "development" here aswell The swap is "done" and car went "test drive" BUT it seems the clutch(maybe gearbox?) is a little bit sad? I bought this clutch kit https://justjap.com/products/xtreme-heavy-duty-organic-clutch-flywheel-kit-nissan-skyline-r31-r32-r33-push-type "Problem" is that the first gear is hard to put into and it seems that the clutch is not disengaged. It was not the problem with the old clutch...(or like sometime the first gear would not get as easy specialy when the fluid was cold) So? Can it be like...bad "install" or is the clutch wrong ((it should not have been) i done research to get the right one) Or is this "normal" with new clutch and needs to be break in?
    • @Duncan I can try  and thanks i did not thought about VIN and part numbers for 33/34. @GTSBoy yeah it looks like iam gonna do that
