  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
as tempting as it is because theres so many im sure they wont miss one - they friggin breed like rabbits in our street the girl nex tdoor is expecting in april she's only 16. When we first moved here there were none now there 20 of the little buggers even my friends bitch how they have to play dodgems!
Originally posted by 33Spec2
coz a hairy muff muff is nasty!
well for once i was just going to bite my tongue (no pun intended) and move onto another subject.
As long as theres the reward there to make the pain go away it may be worth it haha
oh its a cul de sac paul and its got a nice long run up into it with a nice little corner thats fun to go around as fast as you can - in fact the whole suburb is my own personal obstacle coarse even the brakes get a good work out when a kid decides to run across the road at the wrong time.
just dont understand why they dont go play in the friggin park! but then again if i had that many kids i would tell a few to go play on the road too haha
    • I bought one for a 32 and it was junk, found its way into the bin
    • have a look at the other 2 stock rubber strips marked in blue. As you can see, they press against the cooling panel and leave marks. If the cooling unit panel isn’t there, the strip press against nothing therefore have no use. So Nissan was thinking ahead when they manufactured the cars, as they must’ve known people will install the panels in the future. Otherwise think about it, why else would they be there? Therefore that in itself directly infers that cooling panels do something. It might be to stop water and stop some air from going above the cooling panel so more of the air can be redirected between the cooling panel and the front bar. I tried to take a pic of it while the bonnet was closed but u can’t see shit in the photo
    • @DraftySquash @Duncan i misspoke, or this might be the other way. someone sent me a low res pic of it on It might completely close off the gap in red like in the second pic (second pic has gktech cooling panel on) .The 3 holes are for the plastic rivets used to secure down the front bar. The outer holes on the radiator side go underneath the condenser brackets If thats the case then there’s going to be no air going in through the grill between the bonnet and the bar for the radiator and condenser. Isn’t that bad? I mean less airflow to the radiator and condenser is all I’m saying
    • Interesting. Some of them were tight to lol
    • That's right, simple but works. Run out of load? Rescale the table lol. Want to be lazy and not rescale? Drag the K
