  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
Originally posted by GTS-t VSPEC
I don't think the coke bottle would look to flash though:p
Best thing about the coke bottle is it can be jammed into the tightest, darkest spot in the engine bay. Instant stealth mod :D I've had several coppers look in my engine bay and not one yellow sticker yet.
The Mines guys only *wish* they had a coke bottle. Think of the weight saving :D Actually, I've seen more than one fresh import with small juice containers as catch cans, so maybe the coke bottle isn't the right one for the job. Theres more research to be done in this area, I'm off to buy a Mountain Dew to test with :)
I've seen a decent metal can for $100 with filter, I'll post a link later. Anyone know how much Cypher want for one?
Hehe, the tight-arse import mods, maybe we could start a thread of mods you can do that cost less than $10:p
See'ya:burnout:
yeah theres one of them at SDU so been there done that just ask rev210 hes a big contributer to that one
    • There's no way they left the factory like that. In R chassis there is nothing stopping the steering wheel being put on one spline out from straight, and then adjusting the steering arms to "correct" it (sort of). As well as the indicator cancelling there would also be an issue with how tight you can turn in one direction to the other. The other (less likely) possibility is that the "clock spring" (the circular electronic part that allows the wheel to turn while still having an electrical connection for horn and any other buttons like cruise) might not be in place correctly. I don't have any pics of the R33 (or Stagea) setup but there would be a circular locating tab which sits in the steering column to have it straight...if that is not seated properly then the indicators may not cancel at the right point (and, you might also get a HICAS error since it would think you are driving in circles)
    • It will mostly be bad scoring on the bores, which you can almost certainly fix by machining for oversize pistons. I have to say, I am super surprised that any standard turbos made it 35 years down the track before exploding!
    • Thanks for the info mate was thinking 255/35 rears and 235/40 fronts
    • What's the difference? I would have said that between the front and rear axle lines, there's no noticeable diff between a GTR and an NA 2-door.
    • It will be salvageable. It really doesn't matter what is damaged. Opening up a 30+ year old motor for a rebuild immediately means a complete rebuild of the head anyway. Damaged valves just means an opportunity to put in some nice new ones. And in the modern day, why would you not throw at least a nice set of pistons at something. And if you're doing that, why not rods, and ARP fasteners, and so on.
