  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
Originally posted by Nizmo
me and my friend spooked a mate of ours out once - pretending we were from some cult looking to recruit him thru emails etc - spooked him cos our little cult knew so much about him and he hadnt a clue who it was - nearly 2 years later we finally told him - shouldve seen the look on his face. ahhh high school pranks.
Anyway report it but i really think serious thieves n murderers would not mess around with notes!
good point ill just hav 2 wait and c wat happens!
it wouldnt b paul he knows it a n/a!:(
Hmmm , Mackas chasing some panels and pwpt60secf said he was gonna supply .;)
Just joking , I would never accuse anyone but if I found out someone did , would not waste my time calling the cops
*We have ways to make you sorry*
Cheers
Ken
Originally posted by skyzerr33
yeah ken does a strip o gram for u
hahaha classic troy. instead of verbally beating them to a pulp next time i'll just let ken take over. :(
almost my bed time to fellas ;)
No was thinking more of locking them in the back seat after Macka has had another boozy night combined with a particularly nasty vindaloo curry
Cheers
I have gasmask
Ken
Yep , think I will join you.
Going to bed that is.
I mean I will be going to bed and so will you... in separate beds... not at the same address... ohh never mind.
Goodnight all
Cheers
Ken
haha ken. unfortunately i take up 25% of my double bed my cat takes up the other 75%!! Shes got a big arse and if you accidently kick her she latches onto your leg - ouch!
Hmmm , I dont mind an active ***** . Hehehe
Cheers
Ken
micko pops in again for a goodnight call
hey micko can tandi refund money via an eftpos machine?
cause kylie got the wrong modem to start with went back got the right one which was $20 cheap and they refunded via the eftpos machine
didn't think u could do that
    • The fuel pump bracket just slides straight up.  Below is a pic I stole off a site. But basically put hand in for fuel pump, wiggle it all about a bit while pulling up.
    • Went digging Duncan, there's another "item" that sits down under the plenum that the second pipe from the IACV goes down to. I believe that's the one that is apart of the cold start portion, and it then comes back up under the middle of the factory top plenum. I believe you will find it is unneeded on the forward facing plenum on Cheryl.   I just went digging further for some pics on the location of the one way check valve, and found something that confirms my thoughts from the first half of this point. I feel you can just block off that port that is coming down.     I can also confirm, the other line that you were thinking for vacuum that will just need a one way valve put into Cheryl is 100% correct too. The one way valve is normally screwed into the back of the factory inlet plenum.
    • You’re an absolute legend man. Cheers.
    • The rule of thumb for any GTR thats doing a single turbo conversion is..... seqy... and when i say seqy, i dont mean the pos PPG either. *flamesuit on*
    • The ECU does care - it runs the engine as two banks of 3 wrt O2 trimming. So you have to give it the right one. Um....look at the engine bay pictures in the GTR manual? I think you can make them out there. I think the physical wiring diagram might also help.... Actually, I just looked at the engine bay wiring diag. It clear shows the shapes of the connectors. I'd say that R means rear. According to the rest of that diagram, pin 2 of the R one turns up at terminal 55 of the ECU. Which is.....the rear one.
