  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
geoff risbey suggested I get compliance done by global motorworks. I found them to be pleasant and helpful..
but then rang aroung and got some quotes and one was 200 bucks cheaper.....so i took the cheaper quote cause I had no reason not to.
anyway, I dont think I need to actually describe the ordeal, suffice to say tha I really should have gone with global. dont know If I could describe the bullshit ive been through without bursting into tears, but I will never go back to that workshop again, and my arsehole feels like its about 5 foot wide.
See ya Makca.
Paul - you know what's wrong with the sump plug - you ****ed it! Oh, also none of the factory ones are the same. Looks like I will need to pull it out & get the dead bolt removed from the plug, then insert another - shouldn't be too hard but gotta do it so I don't leave an oil trail everywhere:bahaha:
    • Probably a smart choice to buy one vs build, purely for the motivation part as you said! Imagine the metal dust everywhere from grinding all the steel to build one. Ha ha ha!   Also, post a photo of your garage.   Mine is below, this is where I've been cleaning and have already half filled a caged 6*4 trailer. And this is after my cleaning expedition mentioned previously... The middle normally has a car in it, but I'm dumping things in the middle as I sort through them. And poor skyline was dusty and has had the lightest few drops of rain and now it looks atrocious and needs to be dragged back out and washed thoroughly! And yes to the right is technically another bay, you really can only see 2 bays out of 3 in this picture.
    • It's more like on average the things I see a lot of things going wrong. Yes, usually the people who reach out are the ones who are having problems but on average it feels like mechanics and tuners here aren't really competent. I swing between thinking my standards are just way too high and wondering whether people really are just this dumb. I just had the strangest 10+ reply argument on a Facebook group over someone insisting that the factory R34 GTT boost control solenoid reduces boost pressure to 5 psi when it's on and raises boost pressure to 7 psi when it's off despite showing the exact plumbing in the factory service manual and the solenoid behavior detailed in the FSM.
    • I steam cleaned my near new set of volk gtc wheels 14 years ago and farrkkked them lol. The clear coat cracked like spider webbing in several areas. Lesson learnt don't do that. 😭
    • If you don't touch the CAS, then you're fine.
    • Yeah, my moulds and seals are 32 years old now. I think I will continue to not use a pressure washer on it.
