  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
Originally posted by rob77
Hehehe... dont you have a woman? When you have 1 all you want is more :)
yeah.. but yeah.. alright.. i agree..
its cool going to city - chinatown..
and highpoint (shoping centre in asia town)
all the hot asian chicks.. mmm..
but.. i think most of them are too young.. :)
lol @ 33spec... good luck with working it out mate...
well i've had a weekend of pulling apart an r33, too much beer, getting rained on outside autosalon tryin to buy tickets, more pulling apart r33 and a bit more beer..
i'm farkin knackered and am off to bed.. nite
    • Ah right that makes sense.
    • The RPM is just a target, the ECU will adjust things to try and hit that target but it's by no means guaranteed. If the IACV duty cycle is 0 or something like that and it's actually closing up fully then the idle is as low as it can physically go without reducing ignition timing. The problem can be something like the cold start valve in the IACV not closing fully, worn throttle shaft seals, torn rubber diaphragm in the brake booster allowing unmetered air, etc.
    • Apexi, though I'm not comfortable with setting the idle, knowing me I'll f**k it up lol.
    • What ECU is on your car @silviaz? You can just change the idle target table yourself and the IACV duty cycle. Noting that if you play around with the screw you'll also need to revisit the idle base duty table as you will end up offsetting the lot. Another reason why DBW is superior, there's less mucking about.
    • Yep. Saw that on the image above but, wonder if it makes more sense to clean out the iacv because let's say in theory mine is dirty and if I clean it the rpm will drop. If I first go to my tuner to drop the rpm and then go to clean my iacv won't it drop further or is the rpm a fixed number?
