  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
yeah i used to know them too - was going to get them to do it while they were at new town one day but i no longer work there so thats no much good!
been like that for 6 months now - so no it aint getting any worse :mad:
yeah. that'd be good.
Car is in a million pieces, but it looks shithot. combination of factory silver paint, muffler-dragging suspension and buddyclub P1s make for a surprisingly sexy combination.
May need to address a few minor panel issues and the front fac-option spoiler too. will be a good excuse though.
hopefully by then the full stereo transplant will be complete too.
paul,
I am a **** for cheesy rice culture.
First and foremost I think mine is probably a cruiser. it will be made to go fast in time, but will incur the wrath of my penchance for extremely loud music.
In the immediate future its more likely to be a fast ricer tho - if you had to put a label on it.
engine work (once everything goes back in)
turbs back exhaust, HKS pod, HKS AFR, cold air box to come in the VERY near future (maybe as soon as next weekend, depending on my saturday night).
other: tein coilovers on each corner (with associated minor damage to the front quarter panels from rubbing associated with going from 215/35s to 245/45s!), and my nice rims.
coming: bov, boost guage and bleeder of some descritption likely to follow soon.
skyzerr33, have you checked out the boots jay95 is selling? Don't know how they compare to pauls ($15 for Pauls may be better value), but the leather Jay uses is good stuff. Hell of a lot better than the factory vinyl stuff. Lets compare boots at the next cruise :mad:
Oh yeah, my peeling dash pissed me right off, so I sat down and painted it over the holidays. Its not rice, I swear!
RIIICEEEE!!!!
what color is it now denish?
black = not rice something else equals rice
    • Yes...but look at the numbers. There is a tiny tiny fraction of the number of Joules available, compared to what is used/needed. Just because things are "possible" doesn't make them meaningful.
    • Thanks for taking the time to post that ! If anything changes or happens please do update us.
    • Somehow Vertimass/Oak Ridge National Labs has figured out a catalyst that can convert ethanol into C9-C10 hydrocarbons in basically a single step without ending up with a bunch of ethylene or similar waste products: https://patents.google.com/patent/WO2023224867A1/en I still don't think anything like this will keep us from needing to transition to EVs regardless along with all kinds of other electrification, but things like this will go a long way towards alleviating the problem of how to electrify things like planes. Renewable diesel is seemingly an easier problem as well, Chevron is already running refineries for the stuff and the primary feedstock is tallow and other waste fats from agriculture.
    • Ok so I have sorted everything with my uniclutch and  i can offer up a bit of feedback and some things that might help others.    I found problems with factory damper line. Weird shit and had trouble with peddle adjustment    I used this https://au.gktech.com/products/r33-gts-t-skyline-braided-clutch-line?_pos=2&_sid=22b01b9b9&_ss=r Also when adjusting peddle leave a bit of play. You can get into a over stroke condition easy.. Make sure you can push the slave forward after adjusting to confirm fluid can return to master then you will need to pump it up heaps…..not sure why but that’s how it is.    last thing the splined adapter is machined perfectly. If your input shaft is old like mine was I would put a bit of valve grinding paste on it and stroke it like a 15 year old. Just to give it a tad more clearance and to better match it to the spline.    reason is on a near flat shift I have had situation where the peddle returns a millisecond after you lift from the clutch. No slip or anything but I reckon this is due to tolerance on the spline being way tighter than stock clutch and binding for a sec. I think this will go away but also my spline was old. Box is old so I guess I should have checked better. It’s a super neat fit.    it feels light as and holds awesome without any noise
    • My Fuga Hybrid is JDM, 2014 model but very similar to the V37 from the looks of things..same platform just physically larger and very comfortab;e
