  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
Cool.
I waas gonna get my front camber increased to help with the MC day. I think you have said before that 3 degrees would be the max.
What do you advise I get it set to & forgetting tyre wear for the moment would you suggest I leave it set at maximum for my use as it is only a weekend car as you know.
Originally posted by Micko
Cool.
Absolute max and your tyres would last less than 10K before the insides were gone.
Would suggest you try 1.5 deg or so which will give reasonable handling and some tyre life.
Other prob with too much camber is the car wants to duck and weave on all but smooth bitumen.
Cheers
Ken
OK then - it's set to 1 degree or so now so I might leave things as they are.
Regarding the exhaust - can you suggest who I can get to make front pipes that will bolt straight to the turbs (i.e. remove the standard dumps as well) & any idea what I should pay?
You need to make it in sections , ie. the dump including wastegate bleed type pipe ( ala HKS dumps ) and then the front pipes.
Make it as one unit and you will never get them on.
Butler exhaust did a set for S dickson ( grey GTR up your way ) and SWORE he would never do another set.
Jeff Garland at Exhaust Dynamics could be worth a shot but at the end of the day , it is a lot of money for a relative small gain.
Would expect dumps and front pipe will be around $ 1500 for a good stainless setup and you will gain maybe 15KW.
Apexi power fc is about $1700 and have been told is good for 30KW.Also it 5 min job plus tuning
Cheers
Ken
I am still around doing lab write up which is due 2moro :(
cheers
Joe
here is the preview
Abstract:
The isolation and identification of bacteria from a sample of swamp water proceeded over a period of three weeks. The differential and selective methods were used to distinguish colony morphology, samples were observed under a microscope, gram and spore stains. Gram positive organisms and biochemical tests were used to distinguish gram negative organisms. From the biochemical tests, using the API 20E system, it was determined that the organism A (Isolate 1) was Pseudomonas and the organism B (Isolate 2) was Klebsiella. Using some of the characteristics observed of the isolates it was determined that the bacteria in the MSA was Staphylococcus and the bacteria in the NA was Bacillus.
    • Yes...but look at the numbers. There is a tiny tiny fraction of the number of Joules available, compared to what is used/needed. Just because things are "possible" doesn't make them meaningful.
    • Thanks for taking the time to post that ! If anything changes or happens please do update us.
    • Somehow Vertimass/Oak Ridge National Labs has figured out a catalyst that can convert ethanol into C9-C10 hydrocarbons in basically a single step without ending up with a bunch of ethylene or similar waste products: https://patents.google.com/patent/WO2023224867A1/en I still don't think anything like this will keep us from needing to transition to EVs regardless along with all kinds of other electrification, but things like this will go a long way towards alleviating the problem of how to electrify things like planes. Renewable diesel is seemingly an easier problem as well, Chevron is already running refineries for the stuff and the primary feedstock is tallow and other waste fats from agriculture.
    • Ok so I have sorted everything with my uniclutch and  i can offer up a bit of feedback and some things that might help others.    I found problems with factory damper line. Weird shit and had trouble with peddle adjustment    I used this https://au.gktech.com/products/r33-gts-t-skyline-braided-clutch-line?_pos=2&_sid=22b01b9b9&_ss=r Also when adjusting peddle leave a bit of play. You can get into a over stroke condition easy.. Make sure you can push the slave forward after adjusting to confirm fluid can return to master then you will need to pump it up heaps…..not sure why but that’s how it is.    last thing the splined adapter is machined perfectly. If your input shaft is old like mine was I would put a bit of valve grinding paste on it and stroke it like a 15 year old. Just to give it a tad more clearance and to better match it to the spline.    reason is on a near flat shift I have had situation where the peddle returns a millisecond after you lift from the clutch. No slip or anything but I reckon this is due to tolerance on the spline being way tighter than stock clutch and binding for a sec. I think this will go away but also my spline was old. Box is old so I guess I should have checked better. It’s a super neat fit.    it feels light as and holds awesome without any noise
    • My Fuga Hybrid is JDM, 2014 model but very similar to the V37 from the looks of things..same platform just physically larger and very comfortab;e
