  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
aw u home today shannon - im at work :D
Aidwin will pass on the sandwhich and other food stuffs.
As for dodgy foreigners probably haha my dad is going to taiwan in a couple of weeks so if this was after he came back i would be pretty suss!
GTS-t V-SPEC
Doesn't my sister drive ya crazy with her evo talk? I listened to her for half an hour wobble on about them on the weekend. I told her to shoosh cuz I don't like anything with triangle tail lights, JUST tryin to get her to stop. Of COURSE she had her Ralli-art hat on. She's a funny one.
Make sure you give to my Dad over his bald bit at the front! Give him a kick up the bum for the Pulser to. He used our money for that and now look where it is and has been sitting for so long. Then, after paying roteries out for years, he comes home with one? I can't work him out. I dunno, maybe you can.
If I can find a good photo I will stick it on here for all to see!!!!!
Everyone on this site can laugh at him then. That'll teach him!
R31 Chick,
Your sister is mad about EVO's and horses, she can't decide which she want's more:D
The Pulsar has sat in the corner for a while, but I think your Mum is going to use it for hill climbs one day.
The Chooky is being finished off so Evan can drive it, while he finishes building his.
Hope you find a photo:D
See'ya:burnout:
    • Yes...but look at the numbers. There is a tiny tiny fraction of the number of Joules available, compared to what is used/needed. Just because things are "possible" doesn't make them meaningful.
    • Thanks for taking the time to post that ! If anything changes or happens please do update us.
    • Somehow Vertimass/Oak Ridge National Labs has figured out a catalyst that can convert ethanol into C9-C10 hydrocarbons in basically a single step without ending up with a bunch of ethylene or similar waste products: https://patents.google.com/patent/WO2023224867A1/en I still don't think anything like this will keep us from needing to transition to EVs regardless along with all kinds of other electrification, but things like this will go a long way towards alleviating the problem of how to electrify things like planes. Renewable diesel is seemingly an easier problem as well, Chevron is already running refineries for the stuff and the primary feedstock is tallow and other waste fats from agriculture.
    • Ok so I have sorted everything with my uniclutch and  i can offer up a bit of feedback and some things that might help others.    I found problems with factory damper line. Weird shit and had trouble with peddle adjustment    I used this https://au.gktech.com/products/r33-gts-t-skyline-braided-clutch-line?_pos=2&_sid=22b01b9b9&_ss=r Also when adjusting peddle leave a bit of play. You can get into a over stroke condition easy.. Make sure you can push the slave forward after adjusting to confirm fluid can return to master then you will need to pump it up heaps…..not sure why but that’s how it is.    last thing the splined adapter is machined perfectly. If your input shaft is old like mine was I would put a bit of valve grinding paste on it and stroke it like a 15 year old. Just to give it a tad more clearance and to better match it to the spline.    reason is on a near flat shift I have had situation where the peddle returns a millisecond after you lift from the clutch. No slip or anything but I reckon this is due to tolerance on the spline being way tighter than stock clutch and binding for a sec. I think this will go away but also my spline was old. Box is old so I guess I should have checked better. It’s a super neat fit.    it feels light as and holds awesome without any noise
    • My Fuga Hybrid is JDM, 2014 model but very similar to the V37 from the looks of things..same platform just physically larger and very comfortab;e
