  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
Originally posted by R31 Chick
Thats right, you got that barbie tonight ay!!  Sorry, got other plans.  I'll let you have one less.  I didn't ignore ya either, I told ya Adrian had gone, come on!
Hey i didnt say you were invited :):D
LOL ITS OK!
Joes going to woolies and then a petshop...
hang on...i cant remember him having any pets?
Originally posted by Nizmo
Macka - you trust Joes meat haha?!
I'll get bread rolls etc if u wish.
Paul sure what do u want?
Thanks sweety...
Paully Yes i am gay..Dont you remember last friday night?
See you 330 then down the tav with the trevs
Hey skyzerr got to give him credit :)
or maybe a shovel hehe
    • Hey all, I did a voltage test with the car (video attached) not running for 3 days. And here is some interesting stuff: - Battery voltage is 12v (I had the key in the ON position) - Drops to 9.76v while cranking then quickly goes up to 14.5v - You will notice there was a sorta slow start but not as slow as it usually is. - Idle surprisingly was better at just over 1,000rpm instead of 1,100 rpm. - I turned on the A/C, radio and headlights in the video and the voltage remains the same - I haven't cleaned the grounding wires on the chassis yet, that's next. - Battery drops to 12.6v when I turn off the car and wait a bit Seems like I might have a parasitic draw? I do have an immobiliser system which does drain the battery more of course but was wondering if there is anything else I should be looking at fixing? Does the ground wires on the chassis have anything to do with the low 12v?        SAU.avi
    • My lord that is some low oil pressure as minimum in the manual! I guess the big part will be seeing how it changes as the engine gets more spirited use.
    • Turbotapin   so I am about to be mounting mine up been waiting for the body to get finish at paint. I had a question. I was told our Speedo sensor it originally in the transmission but the cd009 is in the diff on the z. How did you get around this?
    • I definitely do recommend having a fab/grinding/dirty shed or area to keep all that grinding dust out of your main shed.  But you're right, it doesn't matter how much room you have you still end up filling it! I might even do a short video which will make it easier to fully take in the horrors of what I've created...
