  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
Originally posted by GTS-t VSPEC
Ken,
Did she? *sob*
Joe, Food yes, but not entertaining:p
See'ya:burnout:
Nah , just kidding .
Was that you in the chair under Niz ??
/thinks
*lucky sob *
Cheers
Ken
No shitfights yet, we will leave it up to a poll from SAU members on who goes in if we have more than 10 cars wanting to enter.
See'ya:burnout:
10 cars , where is it being held and will we get that much room ??
Cheers
Ken
Originally posted by darK
ken: when it comes time...
should i just go after a 92 model gtr.. rather than an 89?
Depends what your after.
Like any car , age will mean more chance of being hammered.
You will be amased at the amount of * only 50,000km * 89 Skylines will appear next year.:P
Price will be cheaper for an 89 but would have to weigh up the pros of having a more modded older car or a less modde ( read hammered ) younger one.
Unless you are going to pay cash or have a good ncb with your parents insurance , your time is 8 years away.
Cheers
Ken
Ken,
It's at Belmont again, but if we get in early then we will get the best spots:D
See'ya:burnout:
Paul , chances of getting 10 spotgs together in that pokey hole is gonna be slim.
Either split into hardcore and others or maybe just select one model of each and work on a better display.
Quality b4 quantity.
Cheers
Ken
    • Yep, the plan is to do some work in Japan, as I mentioned above possibly keeping it there longer than November 2025. Frankly, I'm not dealing with TopRank ever again and, because my car is no longer with them, I could work with BBL/GY directly👍 But alas, I'm not looking at major bodywork just yet.
    • Yeah I had the probes on the battery terminals.  Sounds good. What reading should I expect to see in a car that runs well?
    • I went for the scissor lift option, gives a 3ft lift at full lift. I wanted a 2 post but my concrete wasn't deep enough to secure it properly
    • Depending on exactly where that voltage is being measured, that is most likely the battery is f**ked. If the multimeter probes are on the battery's own terminals, then it is f**ked. If they are on the car's terminals, then there is a bad connection. Either are fatal to the attempt to start it. Literally just put it on the 20VDC range, put one probe on the battery's -ve terminal (ideally not the car's terminal) and the other on the block somewhere exposed/metal, like an engine mount bolt head. You can also test the earth lead is steps, so from battery to body earth, body earth to engine connection point, engine connection point to some other spot on the engine, to see if you can isolate where a shit connection actually is.
    • I meant to write 50 originally and then double checked the price and found it was ¥12m (125k) and came to edit it and realized I had accidentally added and extra 0 in the first place lol
