Originally posted by Nizmo
haha havent u had enough of me for one weekend paul? :D U saw it today its filthy if i dont do it then it'll be ugly and weird smelling (although i have either got used to it or its disappeared) for another week.
Quick question: My steering wheel vibrates at 80km and by 120km its shaking hella bad - its had a wheel alignment done but its still like this and its really annoying! Anyone know whats causing it?
Wheel Balance or your nuts are loose.
Cheers
Ken
  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
as in steering wheel loose? how do i tighten it - cos i wouldnt be surprised if that is the case :D
wheel.. as in allow wheels..
not ur steering wheel..
watch out..
coz it could fall off.. and do a lot of damage
Originally posted by tenzero
Thanks Ken will do. I prolly would have used the RAC if you hadn't said that...so good timing.
Cheers.
D.
The RAC will spend more time doing the
* rip in seat , mark on rear squab , dirty hoodlining type report which any schmuck can see by using there eyes.
The important , check front end play , compression or leakage test, check syncros and oil cond test are bypassed cos they are baffled by the lack of V and too many camshafts.
Cheers
Ken
Cheers
Ken
Nice, will keep all that in mind when I need to get one checked out.
Cheers.
D.
Wheel balance done last week - alignment done this week and the guys that do it are pretty good at what they do - so i ruled that out!
Well then they must have got it wrong then.
Have you hit any kerbs or suddenly heard a loud bang not long after the wheels were balanced ?
cheers
ken
    • Not R7R. Meant to type R&R, obviously enough.
    • Bugger "making it look stock". I put one conventional internally fused Hella relay behind each globe. I just pulled the plugs off the back of the globes and built new loom segments with male and female plug parts to match up to the original loom and the globe, and used the original power wires to each globe coming from the switch through the original loom plug to trigger the relays. Ran a big fat (also separately fused) power wire across the front of the car to feed all the relays. It's as ugly as f**k, but it is wedged down between the headlight and battery on the RHS and the airbox and headlight on the LHS, and no-one ever looks in my engine bay, and on the odd occasion that they do I simply give no f**ks for what they think. Fully reversible - not that you'd ever want to. For f**k's sake. It's a Skyline. They made million of the bloody things. We've been crashing them into roadside furniture for 30 years now. There is a negative side effect to putting relays on the headlights. The coil current is too little to properly clean the contacts in the switches and they get blacked up and you have to open them up every couple of years and clean them manually. I have 25 years of experience on this point.
    • I was poking through the R34 wiring diagrams vs R33 and noticed that the R34 has proper headlight relays while the R33 is like the R32 and sends full headlight power through the headlight switch. I'm not afraid of wiring but I really would like to do this in a way that looks OEM (clipping into open positions on the OEM relay box) and also unlike the factory wiring which interlocks the high beam and low beam on the halogen series 1 GTR headlights I want to make it such that turning on the high beams keeps the low beams on as well. Any advice on how to locate the specific connectors + crimp terminals + relays I need? I was thinking one NO relay for low beams and another for combined high + low running off the factory high beam headlight connector. I don't really want to splice into a crusty old probably discontinued factory harness so fully reversible is my goal here.
    • Pretty sure they run the same engine as the Q50 hybrid which specifies 95 RON.  I ran 98 in mine for a while, but it made no difference in performance or economy, so I have been using 95 for the last few years.  I have never hit 6.0L/100km, but have returned mid to high 6 on the highway.  Being a hybrid, fuel economy is a lot more dependant on how you drive it.  At 110km/h, mine never goes into EV mode on the highway, so returns closer to 7.5L/100. urban driving can return low 8s if you are careful or over 10 if you are a bit more enthusiastic on the throttle.
    • About a quarter of what you want to do. It's only R7R, not R&dismantle&replaceparts&reassemble&R. ? It is stock. I already told you, you will NOT have broken those. It's f**king 4th gear for Christ's sake. You just chipped the teeth off.
