Heheh yeh :D
The fwd ca-18s are almost impossible to find and even then u cant guarentee that it will be in any good condition and there is nothing worse than swaping the engine cause u can save 500 bucks then realising the new engine is almost as bad as the one u took out.
If i rebuild it at least i get a 12months guarentee and know thats its in good order. So its worth the extra in the end.
  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
got bowfinger on video yeah its a funny one when your feeling brain dead - nah i watched gone in 60secs - yeah i know acting is crap storyline is crap but must admit its better storyline than FnF but oooh the cars
shaun: yeh fair enough. most wreckers give a xx month guarentee on their engines as well though... i went through this process when my engine fried and ended up goin for a 2nd hand engine cos theyre so cheap, and its lasted me since (apart from the screwdriver incident)
paul; there wont be any drifitng for a while, dont worry
Booster, Your right, the ca18 is an old engine, most transplant won't be in great condition.
Niz, He popped down to Wanneroo yesterday, so I had a quick chat with him. I think his Mrs gets pissed if he spends too much of his free time doing car stuff.
See'ya:burnout:
Niz,
I love the cars in both movies, I have them both on DVD, they can never be watched too often:D
Can't wait for FnF2, that will suck, but I love cars:D The acting can't be as bad as High Octance 2, those kiwi's piss me off.
See'ya:burnout:
Yeh alot of wreckers will give a warranty but no wreckers over here have the engine. i found 1 engine with a siezed turbo and it was a rwd. Even if i could get it in which is doubtfull (according to some sources) i would need a new computer or even remap the current ecu for around $500 which is more money again. I think ive done enuff research to come up with a good result form reasonable money.
    • Thanks Murray, appreciate the advice, a few things to think about now 😀
    • After my million questions, I'll throw in my 2c now.  If I was in your shoes, I would buy the best/most modern ECU available. A Nexus S3 would fit the bill. It is highly likely that this ECU will last the life of the car, regardless of whatever ECU manufacturers develop in the future. Modern ECU's are amazing and will still be amazing in 10 or 20 years time. If you can get e85 relatively close to where you live, I would buy a flex sensor and size the injectors to run e85. I'd go a Walbro 525 fuel pump with relay wiring kit.  Turbo wise, I'd hit up HyperGear and get a pair of the biggest bolt on turbos.  Now for the safety side of things, I'd have the tuner setup the tune to be very soft/safe on 98. Then on the flex tune, a lot of the timing can be put back in on the top end (I'd run full boost on both tunes, but manipulate the power with the timing). This also has the benefit of hopefully delaying the, "bored now, need more boost" that comes with owning a modified turbo car. If you spend most of your time on the 98 tune, the few times your on e85 will hopefully stay special/fun.  The bad news. As your paying for labour and tuning, I don't think this will happen with $10,000. This might be the motivation to learn to do it yourself though, that way instead you'll have the built car and change from the $10,000
    • Cheers Duncan, on club reg and very much a weekender, don't drive it all that hard and don't intend to go overboard at any point in the future too. In my 40's and quite mature driver, just want that little bit more from it 😉 Sounds like, after ensuring everything is in good condition, ECU, Injectors, Fuel Pump and a set of turbos is likely to be my path forward.
    • 15 years is not too long to hold onto something like that, right?
    • Hey man,   By any chance you still have sunroof for sale ?   Thanks
