  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
hey kyles
your poor cat get a bit of a snip n chop? my cat is pretty territorial too, she was beating up a doberman at 5 weeks old, the vet looks at her and goes that is the biggest healthiest female cat ive ever seen - she's big but she's all muscle.
Originally posted by Kyles
my cat rexy went to the vet today for an opperation :P naughty *****s been getting into fights. No doubt with the rockwheeler at the top of the street rexys trying to claim territory with. Silly cat.
Hehehe, so far it's bleeped two c o c k s and one p u s s y tonight.:P
Cheers
Ken
Originally posted by GTS-t VSPEC
Niz,
Molest sounds good:D
See'ya:burnout:
yep , molest him with a baseball bat.
You can't make him look any worse and hell , it may be an improvement.:P
Cheers
Ken
Originally posted by gtrken
Hellooooo , wheres the weak , nana nap Troy boy ??
Cheers
Ken
hes at home.. weft me wall awone by mwy wittle sewf :P
Rexy's balls was cut off ages ago. They where so damn big and he never put his tail between his legs so we got him snipped. But they only cut 1/2 of them off!!!??? what the??? halfies!!! hehe
Anyways he walked around with his tail between his legs for a while becuase he was embarrased..
He had abscess on his head that had to be drained. Caused by fights.
    • Hi guys, planning to get 18x9 +25 in fronts and 18x10 +25 in rears been reading the whole thread and cant really find anything   Anyone know if these will fit a r34 gtt with no scrubbing or guard work needed?
    • They usually get made by hand as part of any such swap.
    • Was planning on getting an R35 MAF and the adapter, should this be okay? Also any idea where I could get my hands on an intake pipe?
    • I mean yes, if you're starting from scratch on an unknown engine yes you don't need to be doing all kinds of math in the background but if you're doing relatively minor changes like AFM + injectors + boost up with some aftermarket turbos it takes quite a bit of math if you want to do something like maintain OEM fuel + timing tables but compressed and then a bit more load scale up top. I think I've spent too much time working on big engineering nightmares though so I'm a big fan of trying to constrain the scope of whatever work I'm doing as much as possible and trying to get it right before moving on. For example, a local owner just did the usual E85 + single turbo conversion to his R32 GTR and nearly burned his car to the ground doing some spirited driving up the local mountains. Turbine is unshielded and too close to the hood insulation. It's tough to balance "just get the project done" and "seemingly small details can cause massive setbacks I'm not willing to deal with".
    • No idea about Neil's steering wheel, but I have the same behaviour in the Stagea. I doubt it has ever been messed with so might be normal. Indicating to turn right at a roundabout and correcting even a little bit to the left to go around will cancel the indicator. Never considered it an issue other than it being a bit odd.
