  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
Originally posted by Strich9ine
YAY!!!!!!!!!!!!!!!!!!!!!
Booked my clutch in for Thursday morning at Auto Clutch!
DCB 9puck clutch with 2500lbs pressure plate, re-machined flywheel, and thrust bearing..
so all should be right for friday's cruise.... just hope i can "bed it in" before then!
How much was it?
Originally posted by skyzerr33
that setup will be about $850 for kym dan
we should call ross and tell him what a twit kym is so he charges more hehe
AHAHAHAAHAH!!! :-)
the one that PSI did for me is 2600lbs... i have gotten really used to it now :-) i think mine came up to about 850 aswell but brett used a REALLY good quality one and is really not that hard to push in! Troy next time you hoon past gimme a call and i will let ya feel my clutch! not crutch ahahha!tell me what you think of it..
i hated it 1st of all but really am getting used to it... it's a lot different from a hyundai clutch Kim :-)
    • Son, in this country, that is a piece of Gyprock. f**king drywall. FFS! I also like the autocorrect of trailer to tablet. I was reading it and thing, "what the hell drugs is he on?" Then the photo made it clear enough.
    • SO whats the deal with this issue? I've read a heap of posts from the infinity owners in the US having full engine swaps done under warranty. Most claims are done on earlier cars than 2019 but I'm sure I've come across claims of 2020 models also having this issue. I like the 400r and Q50Red/S but can't fathom dumping close to 50k on a car with terminal issues!!!
    • The above video is working normally. That is, that's how the right hand indicator should cancel when rotating the wheel left.
    • I noticed that I could see creatures on the moon when I turned my new headlights on. I thought I should check the alignment. It's pretty rudimentary but I just grabbed some dry wall and put it against my tablet and made sure the beam was below the height on the headlights. Ie the beam is at 600mm on my car, I just made it lower than that 7.5m away.  Not the best but it'll do until I can do it properly at the local shops.
    • As @Duncan said - the bores are most likely to cop it. But anything can and does happen. Rods are cheap. Rods are good. The work to rebuild the motor will be 30x the price of rods. You won't notice it.
