Originally posted by caminperth
tell that to the little jap engineer who slaved for years to produce your gtr.. :)
no engineer - no technology - no go fast gtr... :)
Hoy , don't cut my post to suit yourself !:)
In context with the next line
Making it stay up is a little harder without correct design
is an acknowledgement that engineers are needed.
What the guts of this little post session is that we all need each other but young people these days think they all need a degree in something when a lot of them will never get a job in that field anyway.
Sometimes if you ain't got , you can still earn a good living by manual means.
cheers
ken
  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
Alex u ever see a old school 300ZX around with the plates Nizmo around those parts - one of my friends lives in pickering brook and i used spend a lot of time in the ZX up in kalamunda but now my friends have either got their licenses or moved back down to flatland etc i dont take the line up their often.
Um left school at the end of 98 beginning of 99. I was suppose to be in the class of 2000. Im 19 going on 20 in may.
true - sorry for that but that first line was begging.. :) no hard feelings at all.. i think alot of the people building the things around us.. and it does take an art.. but again, it's like anything - there's a few good ones who carry the rest of the mediocre.. i wouldn't go glamorising some guy who can weld stuff or use a spanner..
i agree with you that both professionals and trades need each other.. not sure if i agree with what you say about people not getting jobs in their fields - unless you're talking about arts degrees... sorry - got a pet hate of those "do my 5 years of study for my degree to get nowhere" people.. no offense meant to any of you who may be this type of person.. :)
cheers
ken
    • Was planning on getting an R35 MAF and the adapter, should this be okay? Also any idea where I could get my hands on an intake pipe?
    • I mean yes, if you're starting from scratch on an unknown engine yes you don't need to be doing all kinds of math in the background but if you're doing relatively minor changes like AFM + injectors + boost up with some aftermarket turbos it takes quite a bit of math if you want to do something like maintain OEM fuel + timing tables but compressed and then a bit more load scale up top. I think I've spent too much time working on big engineering nightmares though so I'm a big fan of trying to constrain the scope of whatever work I'm doing as much as possible and trying to get it right before moving on. For example, a local owner just did the usual E85 + single turbo conversion to his R32 GTR and nearly burned his car to the ground doing some spirited driving up the local mountains. Turbine is unshielded and too close to the hood insulation. It's tough to balance "just get the project done" and "seemingly small details can cause massive setbacks I'm not willing to deal with".
    • No idea about Neil's steering wheel, but I have the same behaviour in the Stagea. I doubt it has ever been messed with so might be normal. Indicating to turn right at a roundabout and correcting even a little bit to the left to go around will cancel the indicator. Never considered it an issue other than it being a bit odd.
    • Does anyone know if this is off centered? Looks like it, when I indicate to go right, but turn my steering wheel slightly left it cancels (was always like that even before I started messing around with it) was wondering if anyone else has the same issue?
    • Nothing photo worthy since last update, lots of little plumbing bits for the AAC/Cold start valves, and unfortunately I still need another couple of parts for the brake booster line and the AAC into the plenum. Otherwise it all looks good to start up engine wise, onto checking the electrics/interior
