nah alex scottish question was because my ex's dad was named Alex then he named my ex's brother Alex then Alex jnr had a son named Alexander. I tell ya the first tiem i met that bunch i was hell confused i didnt know there were three alexs it was a case of "would the real Alex please stand up" so since its a scottish thing i thought it mightve been your folks heritage as well.
Yeah cant say i know many from mazenod or st piglets - i stayed away from single sex schools!
They could know Badams though - Ryan - if your bro has ever played football anyway.
  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
shuto - not relaxed just yet.. but soon.. :)
as for the car scene over there - tried to check it last time.. didn't seem to be much around aside from some idiot telling me power meant nothing and torque meant everything.. pity torque is a derivative of your power curve.. :)
AND he'd sunk 15k into a 200k sti (thats how much they're worth over there) on some more boost and a chip???
    • Was planning on getting an R35 MAF and the adapter, should this be okay? Also any idea where I could get my hands on an intake pipe?
    • I mean yes, if you're starting from scratch on an unknown engine yes you don't need to be doing all kinds of math in the background but if you're doing relatively minor changes like AFM + injectors + boost up with some aftermarket turbos it takes quite a bit of math if you want to do something like maintain OEM fuel + timing tables but compressed and then a bit more load scale up top. I think I've spent too much time working on big engineering nightmares though so I'm a big fan of trying to constrain the scope of whatever work I'm doing as much as possible and trying to get it right before moving on. For example, a local owner just did the usual E85 + single turbo conversion to his R32 GTR and nearly burned his car to the ground doing some spirited driving up the local mountains. Turbine is unshielded and too close to the hood insulation. It's tough to balance "just get the project done" and "seemingly small details can cause massive setbacks I'm not willing to deal with".
    • No idea about Neil's steering wheel, but I have the same behaviour in the Stagea. I doubt it has ever been messed with so might be normal. Indicating to turn right at a roundabout and correcting even a little bit to the left to go around will cancel the indicator. Never considered it an issue other than it being a bit odd.
    • Does anyone know if this is off centered? Looks like it, when I indicate to go right, but turn my steering wheel slightly left it cancels (was always like that even before I started messing around with it) was wondering if anyone else has the same issue?
    • Nothing photo worthy since last update, lots of little plumbing bits for the AAC/Cold start valves, and unfortunately I still need another couple of parts for the brake booster line and the AAC into the plenum. Otherwise it all looks good to start up engine wise, onto checking the electrics/interior
