  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
Originally posted by Boostzor
IT PISSING DOWN!!!!!!
And i lef the window of the car down, bah its not mine:elaugh:
U can get imitation absynth here but u cant get the good stuff. last time i had it someone bought it over from france
thats what i thought. the good stuff is illeagle in oz. ull prolly still get some aussie tools who will mix the good stuff with coke too :)
Psiker
Originally posted by SHUTO-BOY
im not sure, but it was an old Lancer coupe
- 15 secs for a SOHC is pretty damn impressive
it was pretty good. mivec sticker thru me off. i thought he had it till i looked under the bonnet when he got the 15.2. insane for a NA. there was a ralliart magna there also which was good for a na too
Psiker
Originally posted by Nizmo
my car gets really picked up by wind i think thats what made the back wing/ boot buckle - hope its ok :)
Good morgnin!
Well Nizmo judgin by the rain and wind outside our building your car is probably flown somewhere to subiaco by now!
I am meant to be at a morning tea which i had paid for down at treasury and finance... unfortunately the call of my skyline got the beeter of me and whilst getting serviced at PSI decided to stay there a bit longer and check out Adam Q (killer T's) car, has a nice subzero plenum on there! i saw what it pulled but dunno if he is aware yet so i might not let the cat out of the bag :-)
Originally posted by 25GTT
Good morgnin!
lol i work next door to the zest i go to. its funny when they come to my work cafe and order like 5 dimsims each and a side of fries :)
i thihk u better let him tell us man :)
Psiker
    • Don't do what I did, use a 300000km old housing with billet gears. The old pump probably was clearanced with saw dust, Edward Lee's special engine treatment sauce and a good odo wind back. I had oil pressure issues, then replaces pump with new housing, new billet gears and 2x track day later binned a motor due to other oil related issues due to a previous engine builder. Long story short, buy a M2 or 3 or 4 N55/S55/S58 and enjoy life.
    • Yeah. "New pump" does not have to mean "massive pump".
    • Well, can you still get an OEM pump, and by the time you're buying a Nismo/N1 etc, just buy another aftermarket pump. It's better to have the pump able to flow more if its needed, than for your pressure to drop off. At any point in time, you're replacing the oil pump in a rebuild. Aftermarket pumps are likely going to be a better economical choice, and they don't have any negatives, even if they can flow more.   Also, when you're saying "replace the pump gears" are you meaning leave a 25+ year old housing in the engine with unknown wear, and just put new gears in? As that sounds silly to me, especially if you do have that minute amount of wear, that means your new pump gears now have a little bit more clearance beside them, which means, whelp, you may not get to build a lot of oil pressure or make a lot of flow.
    • Right, but if you replace the pump gears + put a spline or sine drive gear on the crank on a Nismo/OEM/N1/etc pump at that point do you really still want more flow/oil pressure? Let's say this is a the aforementioned "keep it simple" build, no more than ~400 kW at the crank.
    • Strength. And on the early RB26, full engagement of the pump drive.
