Originally posted by SHUTO-BOY
psiker: do u know why the n/a mitsubishi engines sound loud? almost sound like vtech's,i never figured out why
(it was loud even before i set the rpm redzone to 8000rpm)
i dont know hey. my mates na lancer has a pod filter and it is *** off loud. i can hear him coming a few streets away. for some reason when u put a pod on them they scream like banshees :) cool but very ricey :)
Psiker
  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
that is SOOOO obvious..
its the sound of the suction..
sometimes the pod and the exhaust overlap.. and creates a cool sound..
i understand that, but even the pod on my bros 180 isnt that loud. u can hear it suck like a street walker but it doesnt scream like its just been stabbed 9 times in the back
Psiker
    • 2 things. 1. If you're going to buy a ball joint puller/pusher tool that is not advertised as being for the purpose you intend to use it for, then it is up to you to make sure, either before you buy, or after you first try (and possibly fail) that it will work for that task. 2. WTF? Putting HICAS balljoints back into a car implies retaining HICAS, which is just....dumb. HICAS can lick my left one.
    • After cleaning the contacts in the remote, if it has rubber carbon pads on the buttons, give them a little wipe with a 2B pencil to add some fresh carbon back. Just a little wipe. Not too much.
    • The one door lock not working intermittently sounds odd. But for the other issues I'd suggest to clean the contacts and everything on the little board inside the fob. I had the same issue with unlock working but not lock, and that solved it. It brings such a quality of life change to be able to lock and unlock the car like a normal person
    • Ok, can confirm.  if you use it like a normal human being in the real world, it works fine.  it only starts crossing wires if I keep using the fob over and over again in a very short period. So if I just chill the f**k out, it works 😂😂
