  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
Originally posted by GTS-t VSPEC
Oh shit, I always forget about stupid holidays:D But I'm still free, I have no strings attached:p
See'ya:burnout:
Good to see it's not that time of the month then. Hahahahaha
cheers
Ken
Neice? I don't have any neices:p  My friends 30+:)
Yeah, Mandee seemed nice, and she helped to organise a rather disorganised cruise, so I will try and go:D
See'ya:burnout:
30+
You hang around with your Mums mates ??
Cheers
Ken
I don't mind fast aslong as they know how to drive and don't crash into me:D I thought there Club consisted of lots of slow cars aswell?
See'ya:burnout:
There is lots of slow cars on every cruise.
It's just that on the PPCC cruises there is relatively more lunatic hi speed pilots than the other ones
Cheers
Ken
I'm 26, most of my mates are pushing 30, I even know some old bastards too *points at Ken*:)
See'ya:burnout:
26
* sigh *
I remember when I was..........
Sad
Ken
See'ya:burnout:
At High speed , NOONE knows how to drive.
Trick is for you to assess the situation and decide if the risk is minimised enough to continue.
If not , then just ease off the loud pedal and back out of the position you are in.
Cheers
Ken
Hi Speed is usually for the cars that aren't fast, like that lancer that joins us, he ain't quick, but he'll push the speed barrier hard:D
See'ya:burnout:
I didn't mind the speed of the Lancer ( brave man )
I didn't like the cutting in and out of the non participating entrants( the public )
Cheers
Ken
Ken,
You can remember back that far? You must have a good long term memory:p
See'ya:burnout:
Memory ??
what's that , I don't remember.
You see , I have this disease but I can't think what it's called ....
Cheers
Ken
Ken, Agreed, but decision's are clouded by adrenaline:D
Hi Neo, wondered if you'd join us, saw you lurking:p
See'ya:burnout:
Yep , red mist is the biggest cause of crashes.
That and lack of perception of where the situation is leading to.
Cheers
Ken
PS , Hi Neo
    • Hi soviet_merlin, We appreciate your concern regarding this possibly being some sort of PR/Political hype, I assure you that is not the case, I wish we could claim something like that, but in this case, we merely reached out for comment on the basis of the outrage we too felt, as those heavily in the automotive industry. Ps. the original source in the social media post is CarExpert not CarExplore.    Best, CE.
    • Made a bit of a discovery, but while I was cruising, I randomly decided to test to see if it worked and it showed up on my IC7. The entire time I tested it before, I never thought to turn the ignition on. I only tested it with head lights turned on but with the ignition off. Huge oversight on my end. I’m a dummy. I know.
    • G'day all, I have drilled and tapped the hole for the relocation of the timing belt tensioner. That was straight forward. I'm unsure if I need to also put another hole for the smaller stud that the spring behind the tensioner catches on (this is how it seems to work in its original spot). Or do you not use the spring behind it and just torque it down? Thanks in advance, I did a search but couldn't find anything related and it doesn't mention it in the rb30det sau guide.
    • Hi All,  just thought I would provide an update as I know smooth (Matt) was on this forum from 2003.    my brother Matthew passed away end of may 2024 at the age of 41 from liver failure. I am not sure how many of his original team krazy friends are still on here or active but thought it reasonable to let the forum know.    if you have any photos or pictures it would be great if you could share them.    it took me a while to work out he was active on here.    thanks so much
