Originally posted by GTS-t VSPEC
Ken, I hate annoying the other drivers, will only lead to the inevitable. I always make sure I have enough room and time to avoid any incident, otherwise I just back off:D
See'ya:burnout:
*thinks, is this the same guy who approached a 90kmh bend at ....err ... in excess of 90kmh ??*
Cheers
Ken
  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
Originally posted by Neo
Ken
Glad that you did not use flash photography on the run this time. It makes you a bit paranoid on the freeway.ha ha
Nah , was too dark and shitty for any video or photo work.
Besides , 1hr of follow the leader is a little boring on camera.
cheers
Ken
Yes a dry day would be nice. Although a cold winters early morning is just what the old lass needs
My old lass stays in bed on those mornings and says to get your own breakfast
Cheers
Ken
Hehe, that was cause Troy drives like a p u s s y. He said: "I was doing 15km's over the limit, I'm not going any faster":bahaha:
Poor Kyles must have been bored shitless:D
See'ya:burnout:
I think it was the sideways launch and *****ff down the road on Leach hwy that woke her up from her slumber.
A set of tight buns and a nerd wars plate can only get the attention for so long...
Cheers
Ken
    • Son, in this country, that is a piece of Gyprock. f**king drywall. FFS! I also like the autocorrect of trailer to tablet. I was reading it and thing, "what the hell drugs is he on?" Then the photo made it clear enough.
    • SO whats the deal with this issue? I've read a heap of posts from the infinity owners in the US having full engine swaps done under warranty. Most claims are done on earlier cars than 2019 but I'm sure I've come across claims of 2020 models also having this issue. I like the 400r and Q50Red/S but can't fathom dumping close to 50k on a car with terminal issues!!!
    • The above video is working normally. That is, that's how the right hand indicator should cancel when rotating the wheel left.
    • I noticed that I could see creatures on the moon when I turned my new headlights on. I thought I should check the alignment. It's pretty rudimentary but I just grabbed some dry wall and put it against my tablet and made sure the beam was below the height on the headlights. Ie the beam is at 600mm on my car, I just made it lower than that 7.5m away.  Not the best but it'll do until I can do it properly at the local shops.
    • As @Duncan said - the bores are most likely to cop it. But anything can and does happen. Rods are cheap. Rods are good. The work to rebuild the motor will be 30x the price of rods. You won't notice it.
