Originally posted by GTS-t VSPEC
Ken, I hate annoying the other drivers, will only lead to the inevitable. I always make sure I have enough room and time to avoid any incident, otherwise I just back off:D
See'ya:burnout:
*thinks, is this the same guy who approached a 90kmh bend at ....err ... in excess of 90kmh ??*
Cheers
Ken
  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
Originally posted by Neo
Ken
Glad that you did not use flash photography on the run this time. It makes you a bit paranoid on the freeway.ha ha
Nah , was too dark and shitty for any video or photo work.
Besides , 1hr of follow the leader is a little boring on camera.
cheers
Ken
Yes a dry day would be nice. Although a cold winters early morning is just what the old lass needs
My old lass stays in bed on those mornings and says to get your own breakfast
Cheers
Ken
Hehe, that was cause Troy drives like a p u s s y. He said: "I was doing 15km's over the limit, I'm not going any faster":bahaha:
Poor Kyles must have been bored shitless:D
See'ya:burnout:
I think it was the sideways launch and *****ff down the road on Leach hwy that woke her up from her slumber.
A set of tight buns and a nerd wars plate can only get the attention for so long...
Cheers
Ken
    • Anything above ~9.5V is acceptable. The higher the better, but it will almost always drop to at least 10.5V, if not lower, even with a new big battery and everything else being good. 9.76 is not a concern. If it goes below 9, you'd be sure that there's a problem with either the battery or the connections.
    • It's new almost. Under a year old i think and I've tested it twice at supercheap
    • Glue the head from a Pez dispenser on it. Goofy, or Winnie the Pooh, so something.
    • Adjusting the idle screw is usually (emphasis on usually) just covering up deeper issues. Stuff like the cold start valve not closing properly. Throttle shaft seals on the way out. Coolant temp sensors getting out of spec. Coolant temp sensors especially can be a bear to diagnose because they can fail subtly. My dad just spent weeks chasing down his high idle. He cleaned the coolant temp sensor and everything but the resistance curve just drifts over time and if it's been 20+ years they also get super slow to respond as well. Has a massive effect on fuel economy as if it's off the ECU is going to run richer and command high idle for far longer than it should otherwise.
    • How old is the battery, it's more likely your battery is on its way out.
