WRX's have eskies in the boot :spank:
Take out spare tyre
Fill Tyre well with ice
Chuck shitloads of beer in there
Pass car search at motorcross which your not suppose to take alcohol into hehehe
  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
Well at least thats one thing everyone has one thing in common, they are ugly. They are designed for camping but they slipped up with the side skirts so now they can't go out bush. Typical Holden, can't get anything right!
Sorry Paul, take that back, soughta.
Sometimes ok, winter, BAD! Should go to physio, when I get time I might! Now that I work part-time and all I lead a very busy lifestyle you know!
Fragrence ala Bayley- like roses! (hehe)!
i sat at the lights this morning and i was surrounded by 4 new shape WRX's common as dogshit - all of them Std as well - all bloody clones :spank:
Hehe take a WRX down to manjimup i swear the locals have never seen one before
Aidwin the Lexus 4wd has barfridge and cooler :D
Here that Aidwin, the back seat! At least the name souded nice enough! 1 bottle had to sell for everyone to find out had bad it smells!
Paul, diff oil has to be one of the MOST disgusting smelling things EVER!
    • I think the catch can design is pretty flawed. Evident in the fact that the V2 one moved to a larger top mounted filter which alone would have helped with overflow and reduce restrictions compared with the side filter. I also imagine there was a major improvement to the baffling design. It is worth mentioning that this catch can with the RB20 was never as much of an issue and the high kms RB25 is likely a part of the problem. I have gotten quotes for both a new "Vibrant Gen 3" catch can and to modify this existing ones but that may have to wait until after the track day. I hope the sump/head breathers/drains and cam splash plates will be enough
    • Yep, both. The ratio is 1.8 instead of OEM being 1.7. The rocker bodies are modified with a larger bolt hole and re-threaded with 10mm holes instead of the 8mm YT has stock. Finding out they don't actually fit the stock castings cause a lot of un-impressment by the person in the USA who tapped the new holes for the 'upgraded' YT product. He was very unhappy with them given their previous design did not require 'clearancing'
    • That too, but I think this is why she's put the work into the cam cover baffles. I mean, a catch can should only need to be a catch can, not an oil air separator also. Not to say that putting the effort into having it do a better job of oil-air sep is a waste of time, but doing the sep earlier is always going to make life better. And that should happen now anyway.
    • I think both. Higher ratio and more stout. I think at least part of his lift increase came from the rocker.
    • At 30cm long, you only need 80lbs... Which isn't hard to put that much weight in. Just start to stand on it, but not full force. Even a light weight size 6 lady can do it. If I stood on, I'd get them to about 190ft-lb... And all Id need to do is... Stand...
