  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
thanks mate.. again - muchly appreciated.. what do you drink? :)
as for mods.. it's getting a dump pipe and the cam gear.. and hopefully some good tuning to boot... also getting the cam blet and diff oil done and he's going to go over the whole car.. i told him if anything is broke or near broke - ring me and i'll let him know if he should fix it - depending on $$
that should be good incentive for him to find stuff.. :)
will hopefully run completely different when i get it back.. i just want the surgy power to become clean and sparkly.. :)
paul - not sure.. have been told go 2 deg.. then told go 4.. am going to leave it to him..
basically i want a smooth and full power curve.. not after huge numbers up top cause that won't be very safe with only the piggyback computers i've got running..
Originally posted by Nizmo
Paul my car was only 2/3 rds of a car length in front of yours wasnt it? Joe if it was that far over the white line we wouldve been obstructing traffic - stop exaggerating!!
What? Me no exaggerating... :)
I also have 12" 3rd leg... :)
hahhahahaha.....:burnout:
    • Last year I got a set of MCA street coilovers for my turbo Forester after my son hitting a concrete gutter/wall on a small bridge causing the whole drivers side suspension to get bent because the rain just made the car slide out I love them, I think they were $2400. even had a hiccup of have the wrong hub configuration (my fault) so got onto MCA and they sent the correct shock ends overnight parts from QLD, for free!  I was very impressed with their customer service and quality of the product
    • They've had some weird failures on their brake actuators. One of them was because they added some kind of lubricant to the factory fill brake fluid that aftermarket brake fluid didn't have so it would affect the seals. Another was just mysterious, probably internal corrosion or something eating away at Prius brake actuators. Parts alone for those are a few thousand USD so not a cheap fix.
    • Selling a genuine Nissan Skyline R33 Coupe 8-Pin Power Window Master Switch Part No. 25401-26U10 Price $300   IMPUL Gear Knob – Rare JDM Upgrade Upgrade your interior with this genuine IMPUL gear knob – a rare and stylish addition to any JDM build. Premium quality, perfect fit, and an authentic Japanese touch for your ride.  Price:$300 Nissan Skyline R33 (Series 2) Sedan Tail Lights Immaculate Condition OEM JDM S2 a pair of OEM Skyline R33 Series 2 sedan tail lights in excellent condition. These are becoming harder to find, especially in this state. Price:$900   Located in Melbourne (Western Suburbs) – Shipping available Australia wide at buyer’s expense. DM if you need anymore details.
    • KYBs are typically twin tube, putting them in the lower tier of desireability. Do you just want to replace worn out ones for the lowest cost? I mean, you wouldn't just replace one end of a car, if the rears are a similar age to the fronts, then they are probably nowhere near what they should be, and likely won't be great against brand new fronts. So, to spend ~$800 on 2nd tier dampers, when you could get a decent set of MCA coilovers for <$4k.....? As to the strut tops. 1st up, the Sparesbox site specifically tells you that they are not correct for an R33. Beyond that, why do you think you need them?
    • That's not very Toyota of the Toyota!
