  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
i told him all that
he said its not the turbo. he suggests to get temp probes into the system and find where the heat is coming from.
he says that if hed changed something a great deal then hed suspect the turbo but downsizing the turbine wheel by 0.25" using the same housings wouldnt make a difference. besides we havent changed the compressor side of the turbo AT ALL. so it should be the same
yeah, paul if nengun actually get back to me i will keep everyone updated :D they look the goods, and noone needs me to reassure them how well the name trust/greddy goes!
hehehee :)
damn all you get to go to the drags, while i have to grill damn chickens! :(
paul did u get info from just jap on the os giken and hks cam gear?
adrian :P
Adrian,
I was too busy today, but I'll call tommorow from Work, they retail them cheaper over there, so hopefully with a group buy we can get a decent price:D
Adam, It's all about turbo effieciency, otherwise a thrust bearing may be going?
See'ya:burnout:
    • Did you find that your voltage of the battery wasn't where it's normally supposed to be? for example on my r34, it's at 14.5v when running after a few seconds, but I noticed when I had a rough start and it initially wasn't idling correctly, the voltage on my triple gauge cluster was showing lower than usual. Seems like the alternator is starting to crap itself
    • And, given that you're in NC, go buy an LS7 or something equally sweet and piss that crappy old RB off. Or call up Wesley Kagan and get his help putting a Merc V12 into it.
    • Do a compression test, and a bore scope on the cylinder that lost parts of the plug. Chances are, that cylinder isn't so happy anymore...
    • Update from today; Hard work was completed today behind a computer... Ha ha Hardlines for new fuel lines ordered, and fittings for it to connect up too. Banjo fittings for owner steer ordered too, will be AN fittings. Ordered all the weld on fittings I need to build the PS reservoir too. Only things I'll need left for power steer is a couple of off the shelf fittings for the pump, and to build 3 lines.
