  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
Originally posted by Boostzor
And there u stand, little son of rajab fuantleroy, surrounded by the maladjusted, ever try wearing a bonnet? u should.:bahaha:
lol no reason to tell it like it is :D
hrmmmm bonnet. nah it doesnt set my eyes off :P (unless its carbon fibre :) )
Psiker
(and yes i know what bonnet u mean :( )
Psiker
Nah i dont play online. I have to be able to alt tab out. I am at work after all.
Hey how about 4NIC8 on an old hq wagon
can still alt tab just the same online :D. if u played online i could help ya finish the whole game in half an hour :) all the way thru hell
Psiker
I still gotta build up some levels and that takes time. Remember the good ol days where u could copy items with that little bug
yah back in d1 days. there are alot of hacks out for d2 now. not so many when i started playing :D but its all goodpretty much what i wouold do online is rush u all the way thru hell then do cow hell games with u :) so u gain heaps of exp very fast. ppl mainly only play online to pk or magic find now. its good casue ppl cant take ur items when they pk you
Psiker
    • Nah it factory manual not sure about ratio but it looks like there’s been some work at the rear
    • so I need a new speedo cable
    • Throwing my spoon to the soup here a bit.  When I installed a 044 back in 2012, along with the direct power mod, the car became very difficult to start. To a point I burned one starter motor as I was late for work and tried to get the thing going. With some tuning and careful use of gas pedal when cranking it became bearable. Trying to make this short as possible, but the 044 died after 2-3 years, after which I went with an AEM 320lph pump, which also died after about 4 years to my dismay. After that I went with a Nismo pump, and while trying diagnose an emissions problem, I noticed for the first time that my fuel pressure was 5bar/72psi on idle, and that removing the vacuum line did nothing. After monitoring the situation, and removing the direct power feed and going back to FPCM in attempts to remedy it, I noticed there was fuel in the pressure regulator vac line. Kept the FPCM, installed AEM external regu and the car became sooo much better in every way, including starting. And I had driven it like it was for 11 years.. Anyway, I agree these are likely two different problems, and the FP problem you just haven't noticed before. I do not know much about haltecs, but what first came to mind was the CAS, which probably is not there any more. So how is the wiring from haltec to gauge cluster? How is the battery voltage and alternator?
    • Your car was auto before? You have different diff ratio (auto vs manual i think? or n/a and turbo?)
    • +1 for getting a screen off alibaba, CarPlay/Android Auto is vastly better than whatever navigation cars had 10 years ago. I got an Android screen for my 2015 BMW, huge difference. Fully compatible with factory stuff including iDrive controls.
