  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
Originally posted by Neo
Ken
How are twin turbs setup? to have different spool designs? or to work in unison? Is it feasable to install 2 different turbos one to spool up earlier than the other?
Sorry if it is a silly question.
GTR's run 1 terb per 3 cylinders . Allows to run a smaller terb for faster response.
Supras and RX7 run a small /big terb setup. Small for initial low down spoolup and that then bleeds across to the bigger one. Bit more complicated but can make a torque less motor ( rotary ) very torquey.
cheers
Ken
Originally posted by GTS-t VSPEC
Ken, You still going to Collie?
See'ya:burnout:
yep , have entered , ya still coming.
Will stay at a motel for the night cos it's too damn cold and I'm too damn old to camp outdoors.
cheers
Ken
cheers
Ken
Thanks Ken
    • G'day all, I have drilled and tapped the hole for the relocation of the timing belt tensioner. That was straight forward. I'm unsure if I need to also put another hole for the smaller stud that the spring behind the tensioner catches on (this is how it seems to work in its original spot). Or do you not use the spring behind it and just torque it down? Thanks in advance, I did a search but couldn't find anything related and it doesn't mention it in the rb30det sau guide.
    • Hi All,  just thought I would provide an update as I know smooth (Matt) was on this forum from 2003.    my brother Matthew passed away end of may 2024 at the age of 41 from liver failure. I am not sure how many of his original team krazy friends are still on here or active but thought it reasonable to let the forum know.    if you have any photos or pictures it would be great if you could share them.    it took me a while to work out he was active on here.    thanks so much
    • 😜 hopefully we get this instead of a new R36 GTR due to recent financial problems at Nissan. Nismo to sell a complete kit with RB26 and driveline. All starts making sense (ok maybe not) once the Nissan Leaf's (Leaves?) with stuffed EV motors/batteries hit the market cheap
    • Hi guys , have had allot of time for SAU and has helped me out heaps in the past so I thought I would give it a go , I have my QM1 white NUR for sale 1 of 156 examples built by Nissan. Serious personal messages please if interested and details will be provided , asking 500k
