haha goon - i havent heard that word in ages :D
its just one of those things afterward u have nothing to show for your money its a waste - a good waste but still makes me cry everytime i have to fork out heaps for a drink :D
  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
Nahh i cant really get out there, for some reason im the only person in a rather large group that can count. Ok i had 1 beer that means 1 hour, its not that hard.
So im drving the platoon to mt lawley to see big dave miller play at the velvet lounge
Clients are good to deal with none of em give me hassle cause i just dont take it off em. the only problem is ppl who are just morons now that can get annoying. Oh and companies that are moronic by design, thats even worse
heheh they wernt that bad i have seen worse. i always drink and drive ive been plulled over heaps of times too.
Go out and drink to ure hearts content. Go back to where u parked and count how many drink uve had wait the designated amount of time then drive home. If u cant count ure beers, dont bother, leave the car there. its a good technique
haha 7:20 thats very precise paul!! ok no probs i'll have the gates oh hell opened for u :D
One day i will skipper u pauly although if your saw my designater driver act last weekend u are probably not to eager for that day haha
shaun so many companies are badly managed and really it means the difference between life in death of the company. Its sad cos it ruins the employees morale which then in turn ruins sales etc
my take on things anyway
    • Anything above ~9.5V is acceptable. The higher the better, but it will almost always drop to at least 10.5V, if not lower, even with a new big battery and everything else being good. 9.76 is not a concern. If it goes below 9, you'd be sure that there's a problem with either the battery or the connections.
    • It's new almost. Under a year old i think and I've tested it twice at supercheap
    • Glue the head from a Pez dispenser on it. Goofy, or Winnie the Pooh, so something.
    • Adjusting the idle screw is usually (emphasis on usually) just covering up deeper issues. Stuff like the cold start valve not closing properly. Throttle shaft seals on the way out. Coolant temp sensors getting out of spec. Coolant temp sensors especially can be a bear to diagnose because they can fail subtly. My dad just spent weeks chasing down his high idle. He cleaned the coolant temp sensor and everything but the resistance curve just drifts over time and if it's been 20+ years they also get super slow to respond as well. Has a massive effect on fuel economy as if it's off the ECU is going to run richer and command high idle for far longer than it should otherwise.
    • How old is the battery, it's more likely your battery is on its way out.
