  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
Originally posted by rob77
His dad used to coach marcus, my cousin and me privately cos we all looked like going on with it, marcus was the only one that made it, I gave it up to concentrate on my tee scores and I regret that now :D
i did this with golf, sort of regret it but not to fussed as i know i didn't have attitude to practice as much as i would of had to.
3 handicap at age 15
Hi peeps , bye peeps.
Just spent all day on the bloody GTR.
Pulled off inlet manifold cos it had spat No6 throttle body gasket.
Finished at lunchtime , fire it up and found that the rear turbo gasket had gone too.
Have JUST finished. , 4hrs for the inlet , 9hrs for the turbo gasket. Not fun and I'm glad I didn't have to pull off the front one , thats worse.
Anyway , I'm knackered and going boating tomorrow so bye all.
Cheers
Ken
    • How does this compare to the internally gated g25-550 in terms of power production at same psi and spool
    • Did you find that your voltage of the battery wasn't where it's normally supposed to be? for example on my r34, it's at 14.5v when running after a few seconds, but I noticed when I had a rough start and it initially wasn't idling correctly, the voltage on my triple gauge cluster was showing lower than usual. Seems like the alternator is starting to crap itself
    • And, given that you're in NC, go buy an LS7 or something equally sweet and piss that crappy old RB off. Or call up Wesley Kagan and get his help putting a Merc V12 into it.
    • Do a compression test, and a bore scope on the cylinder that lost parts of the plug. Chances are, that cylinder isn't so happy anymore...
    • Update from today; Hard work was completed today behind a computer... Ha ha Hardlines for new fuel lines ordered, and fittings for it to connect up too. Banjo fittings for owner steer ordered too, will be AN fittings. Ordered all the weld on fittings I need to build the PS reservoir too. Only things I'll need left for power steer is a couple of off the shelf fittings for the pump, and to build 3 lines.
