  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
Ive done country when i was younger then my parents moved back to city when i was 12 to high wycombe but i lived in Mt Lawley in my exs house there for a couple of months then we went to Como. Its sooo sweet living near the city haha less booze buses to pass on the way home :)
Angie has gotta go - Say angie will die because she's not in the opening credits where from memory dylan is :)
ahhhh its sad that i watch it haha my mum likes it so i just watch it as well with her.
mmmm sounds nice. The house is such a mess i cleaned it yesterday arvo but its just back to such a mess again. Have to do it befor ethe folks get home n flip out - Im only one person that hardly spends any time here how i can leave a path of destruction like this baffles me!
hahaha bugger! lol. I was considering leaving troy here and going.. Thought i should stay home like a good girl and look after him. Hes looked after me plenty of times when im sick.
My house is a hudge mess too. I cant see my bedroom floor, clothes everywhere .. text books all over the dinning and coffie table.. and "stuff" everywhere!
well enjoy the rest of your night. talk to you later.. byes!
    • Yes, but it's not as easy as pulling a fuse on anything other than an R32. There's a routine you have to do, involving disconnecting a loom plug and bleeding down the preload.
    • A question for tuning awd, is it possible to disable the AWD? The stagea is an EA/T AWD, Toshi had said on a GTR, he was able to disable it and make it 2wd. Just wanted to double check if this was possible
    • Whoa, that's a name I've not see for a long time! Sorry to hear about the engine / turbo damage.  Fwiw with any engine problems it often really a case of just seeing what happens when it's apart, ymmv - I wouldn't rule out the possibility that the damage isn't even from the turbo failure, or possibly from a combination.  The airflow between cylinders isn't dead even, injectors can go off over time as well, with the turbos overboosting if you didn't have upgraded fuel system there could have possibly been a bit of leaning out - stock triggering is often a bit unreliable by this age too.  Basically its an old engine and a few things could have been going on, and you won't know how much work is needed until the engine is apart.
    • I'm just shocked there's a euro driver on our roads who is thinking of other road users and not attempting to blind everyone. I wonder if Prank uses his indicator too...
    • Its hard to tell really. The Q50 owner's forum talks about it a lot and has quite a few people directly affected, but no idea what % of cars sold actually had the block replaced. Also, there seem to be 2 distinct issues which both get diagnosed by Infiniti as requiring a block replacement (no wonder they are going broke) 1. "Porous block" where coolant mixes with oil through thin or poorly cast parts of the block 2. Head coolant gallery plugs not sealing. If I was noticing engine coolant loss I'd start with cooling system pressure test (as always) and then I'd pull the cam covers and reseal the coolant gallery plugs on both side before worrying about a potentially porous block.  If neither of those did the trick it would be put in a second hand engine out of japan; I haven't checked pricing but I'm sure there are plenty around by now as they've been in production 10+ years
