  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
hey teem, how fairs ye?
happy easter btw.
I need a little help if possible....
anyone know what the little silver boxes in the aluminium "frames"are in the rear corner of the car. I have only one, on the drivers side, and its in the corner on the CAR side of the boot. four or so wires into it, but im relctant to pull it out until I know what it is.
need the space for speakers!
power seatbelts? nah i got my HICAS on the drivers side and then the battery on the passenger side!
Hehe see some of the info does sink thru to my blonde brain - thats why i ask lotsa dumb questions so i learn :D
Paul u can remove HICAS? i thought u couldnt - but i would rather keep it - stuff the speakers!! or is it take it out then chuck it back in.
mmm thing is i drink and i feel fine but it will all of a sudden hit me and by then its too late to do anything about it.
    • The overboost could be more of a cause. Broken turbines usually ends up in the cat, time to engine rebuild. Blown stock turbos can be high flowed with bigger and modern wheels for greater power goals.
    • Yeah was gonna say as it wouldn't line up correctly, I imagine if they put the wheel that way it would mess with the wheel alignment.
    • My Neo turbo only went last year. Not 35 years old, to be sure - closer to 25. But still.
    • There's no way they left the factory like that. In R chassis there is nothing stopping the steering wheel being put on one spline out from straight, and then adjusting the steering arms to "correct" it (sort of). As well as the indicator cancelling there would also be an issue with how tight you can turn in one direction to the other. The other (less likely) possibility is that the "clock spring" (the circular electronic part that allows the wheel to turn while still having an electrical connection for horn and any other buttons like cruise) might not be in place correctly. I don't have any pics of the R33 (or Stagea) setup but there would be a circular locating tab which sits in the steering column to have it straight...if that is not seated properly then the indicators may not cancel at the right point (and, you might also get a HICAS error since it would think you are driving in circles)
