  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
Hello Kym.
I spoke to Phil and Daniel last night! They both remember you. They don't remember much about a fire so please do let me know what happened there!
Thanks for the hint Rev210!
Next time you see me drunk, you will know what I have just done!
Strich9ine,
I enjoy a wide range of drinks and a range of wide drinks.
The cactus juice is a favorite as well. I make a fremented chilli drink that is brought up to 37% alchohol by the cactus juice and I call it "Fire water". Like napalm down the throat and explodes I the stomach like a rack of funelled B52's. It also makes you drunk very quick.
heheh, what are the odds hey. Small world :)
funnily enough, my gf wants to go poke daniel's eyes out with a fork.....
.... him and his mates were being "Stare Bears" gawking at my gf while she was being written a ticket by the lovely police officer outside his house :)
Originally posted by rev210
I make a fremented
Not only a connoiossuer, but a brewery whore too huh?
I made wine once, squeezed the grapes myself, added all the ingredients needed, found out later that 200g of sugar made about 10% alcohol...... i put in 1.2kg of sugar...
...needless to say I discovered the reason it was so potent in a not-so-nice way...
... how do you make this napalm you speak of ?
I take 500gms of habenaro chilli.
blend it to a pulp (outside because the fumes are exactly what tear gas is made from)
add a little yeast and sugar and leave it in a bottle for a few months.
add a small amount of white vinager when done and make to volume with your favorite spirit. This time the mexican cactus juice.
there you have it, drinkable napalm. On second thoughts I won't be trying that one. Sounds a little risqu'e for me....
*runs back to his milk'n'cookies*
Kym, Daniel would have found it very amusing I think! He is a cheeky little sh*t. How long ago was that anyway?
Lovely police officer? There is no such thing?
You still haven't told me about the fire story and I am dieing to know, please!
    • I suppose that's true. Barring almost any situation, I'll never sell so what the market does is kind of irrelevant to me. It's possible I'd make most of my money back. That spreadsheet I mentioned? Maybe I could make back more than what the car's total costs thus far are, but the parts and all that is possibly a different story... Thanks for reading. It was certainly a good moment and just makes the ties to the car that much stronger. It's exciting that the option will be there to bring it over, however I have some plans with a shop that may end up keeping the car there longer, not sure. Coupled with the fact I want to move there and haven't solidified any path yet. So in a way, it feels like I'm in a limbo state that is uncertain; time will tell.
    • No worries, everything worked out in the end. I just wanted to make the point that it doesn't matter where it comes from (I.E Australia), it can be broken or improperly built. I would still purchase from these companies in the future. B2R - Not certain how that finished, this was on a car I wired a few things and street tuned. I know the owner ended up shipping the motor back to Australia for investigation. Hopefully some of it is covered under warranty.  Turbosmart - I always pressure test everything that goes on my car. It's a habit from my career in oil and gas. I run two 40mm's and both had major leaks from the actuator to exhaust portion through the shaft. I returned both, they shipped me back two and one was leaking and the other had a 38mm top (40mm gate with 38mm actuator cap, no idea how that happens). Eventually after a lot of back and forth I found myself with two non-leaking gates. I believe this happens a lot more then people would like to believe but you would never know if you don't pressure test them prior to installation. Crank Motorsport - Issued a full refund and let me keep the seat rails. I turned them into scrap metal for other projects. GKTech - Shipped me out a replacement and asked that I modify it as per my idea and that they would do the same for a future revision. ATP - Can just needed a large shim to bolt up properly.  Haltech - They started an actual proper Beta channel for firmware's a few months back and stopped using the general public for testing. I'm now much happier.  Speedtek - f**k Speedtek. I would love to watch them burn.
    • I've got a Turbosmart wastegate, ATP catch can, many GK Tech parts and Haltech everything. Everything's been perfect, sorry to hear your experience wasn't the same
    • The only high-power RB I've personally seen go pop after running for all of an hour on a dyno was built by B2R, while being remotely tuned by B2R. The only wastegates I've ever had leak like a sieve, return, still leak, return and get shipped back the wrong ones were from Turbosmart. The only final drive that I've ever purchased that were unusable, twice... were from Speedtek. The only seat mounts that I've ever purchased that placed the seats in the door frame were from Crank Motorsport. The only poorly designed parts that I had the manufacturer confirm should have been designed as per what I mentioned were from GKTech. The only ECU I've had firmware updates consistently break things are Haltech. The only catch can I've purchased that didn't fit in its advertised spot was from ATP. So forth and so on... Moral of the story, doesn't matter where it's from. Do your research beforehand and stick with products and companies you've trusted in the past.    @joshuaho96 If you want it done right, do it yourself.
    • Something coarse-ish. 180 is good.
