  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
This is the transcription of the ACTUAL radio conversation
between the British and the Irish off the coast of Kerry,
October 1998. Radio conversation released by the Chief of Naval Operations 10-10-98.
IRISH: Please divert your course 15 degrees to the south to avoid a collision.
BRITISH: Recommend you divert your course 15 degrees to the north to avoid a collision.
IRISH: Negative. You will have to divert your course 15 degrees to the south to avoid a collision.
BRITISH: This is the Captain of a British Navy Ship. I say again, divert YOUR course.
IRISH: Negative. I say again, you will have to divert YOUR course.
BRITISH: THIS IS THE AIRCRAFT CARRIER HMS BRITANNIA! THE SECOND LARGEST
SHIP IN THE BRITISH ATLANTIC FLEET. WE ARE ACCOMPANIED BY THREE DESTROYERS, THREE CRUISERS AND NUMEROUS SUPPORT VESSELS. I DEMAND YOU CHANGE YOUR COURSE 15 DEGREES NORTH. I SAY AGAIN, THAT IS 15 DEGREES NORTH OR COUNTER-MEASURES WILL BE UNDERTAKEN TO ENSURE THE SAFETY OF THIS SHIP.
IRISH: We are a lighthouse................ Your Call.
The rest are too long or in powerpoint form
    • Depends how low and tyre size. Should fit with natural camber, skinny tyres and rolled guards.
    • Hi guys, planning to get 18x9 +25 in fronts and 18x10 +25 in rears been reading the whole thread and cant really find anything   Anyone know if these will fit a r34 gtt with no scrubbing or guard work needed?
    • They usually get made by hand as part of any such swap.
    • Was planning on getting an R35 MAF and the adapter, should this be okay? Also any idea where I could get my hands on an intake pipe?
    • I mean yes, if you're starting from scratch on an unknown engine yes you don't need to be doing all kinds of math in the background but if you're doing relatively minor changes like AFM + injectors + boost up with some aftermarket turbos it takes quite a bit of math if you want to do something like maintain OEM fuel + timing tables but compressed and then a bit more load scale up top. I think I've spent too much time working on big engineering nightmares though so I'm a big fan of trying to constrain the scope of whatever work I'm doing as much as possible and trying to get it right before moving on. For example, a local owner just did the usual E85 + single turbo conversion to his R32 GTR and nearly burned his car to the ground doing some spirited driving up the local mountains. Turbine is unshielded and too close to the hood insulation. It's tough to balance "just get the project done" and "seemingly small details can cause massive setbacks I'm not willing to deal with".
