  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
Originally posted by GTS-t VSPEC
Thankgod it's not targa, don't feel like pulling the GTR out of a tree:p
See'ya:burnout:
There are trees at Wellington dam so don't speak too soon.
cheers
Ken
I think she's staying there too, that way we don't have to get up so early:D
See'ya:burnout:
Huh ??
If you stayed at home you would get an extra hour sleep.
Mickos is 35mins from my place and you had better be here at six
Takes 3 hrs towing and MUST be there by 9.15 at the latest.
Cheers
Ken
Ken,
Well if Frank Ferrari can roll Ray's car on a straight bit of road then anything can happen:bahaha:
See'ya:burnout:
It was straight alright, straight thru a T Junction and over a bank
Cheers
Ken
    • I bought one for a 32 and it was junk, found its way into the bin
    • have a look at the other 2 stock rubber strips marked in blue. As you can see, they press against the cooling panel and leave marks. If the cooling unit panel isn’t there, the strip press against nothing therefore have no use. So Nissan was thinking ahead when they manufactured the cars, as they must’ve known people will install the panels in the future. Otherwise think about it, why else would they be there? Therefore that in itself directly infers that cooling panels do something. It might be to stop water and stop some air from going above the cooling panel so more of the air can be redirected between the cooling panel and the front bar towards the condenser and radiator. I tried to take a pic of it while the bonnet was closed but u can’t see shit in the photo
    • @DraftySquash @Duncan i misspoke, or this might be the other way. someone sent me a low res pic of it on It might completely close off the gap in red like in the second pic (second pic has gktech cooling panel on) .The 3 holes are for the plastic rivets used to secure down the front bar. The outer holes on the radiator side go underneath the condenser brackets If thats the case then there’s going to be no air going in through the grill between the bonnet and the bar for the radiator and condenser. Isn’t that bad? I mean less airflow to the radiator and condenser is all I’m saying
    • Interesting. Some of them were tight to lol
    • That's right, simple but works. Run out of load? Rescale the table lol. Want to be lazy and not rescale? Drag the K
