Originally posted by GTS-t VSPEC
OMG Ken, doing BAS statements? that must have been exciting:p
See'ya:burnout:
yep , would take a lot less if you guys went to bed and stopped annoying me:D
Cheers
Ken
  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
Ken,
Did you get the trailer from work?
See'ya:burnout:
Yep , is round the side. Will load up everything tomorrow and park it up the drive. Thank god for 4wd , backing a loaded trailer up my driveway.
Cheers
Ken
Originally posted by gtrken
Yep , saw that , six or eight special build HKS or some such cars . Modified everything but too pricey and only sold 2 , rest were out the back in the rain.
* SOB , SOB *
Cheers
Ken
Thanks Ken. I'm not goin mad.
Anyone want to make a trip with some SAS boys and couple shnook helicopters ( those the big one?) and recover. Comon Howard put the boys to good use.:D
Thats Chinook
Originally posted by Micko
No probs Paul - dont forget a shower cap - you know what I mean;)
I am getting worried about you 2.
pwpt60secgf I can understand , but Micko ??
Ya got Naomi or if you are lucky her sister.
* thinks or REAL lucky both *
Shit , did I just say that ?
Cheers
Ken
    • Hi guys, planning to get 18x9 +25 in fronts and 18x10 +25 in rears been reading the whole thread and cant really find anything   Anyone know if these will fit a r34 gtt with no scrubbing or guard work needed?
    • They usually get made by hand as part of any such swap.
    • Was planning on getting an R35 MAF and the adapter, should this be okay? Also any idea where I could get my hands on an intake pipe?
    • I mean yes, if you're starting from scratch on an unknown engine yes you don't need to be doing all kinds of math in the background but if you're doing relatively minor changes like AFM + injectors + boost up with some aftermarket turbos it takes quite a bit of math if you want to do something like maintain OEM fuel + timing tables but compressed and then a bit more load scale up top. I think I've spent too much time working on big engineering nightmares though so I'm a big fan of trying to constrain the scope of whatever work I'm doing as much as possible and trying to get it right before moving on. For example, a local owner just did the usual E85 + single turbo conversion to his R32 GTR and nearly burned his car to the ground doing some spirited driving up the local mountains. Turbine is unshielded and too close to the hood insulation. It's tough to balance "just get the project done" and "seemingly small details can cause massive setbacks I'm not willing to deal with".
    • No idea about Neil's steering wheel, but I have the same behaviour in the Stagea. I doubt it has ever been messed with so might be normal. Indicating to turn right at a roundabout and correcting even a little bit to the left to go around will cancel the indicator. Never considered it an issue other than it being a bit odd.
