  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
paul - yea i know.. but i've suddenly got all this low down power at the moment.. and at stock boost.. would like to get used to it and tired of it first before i increase again...:( thinking i'll do the clutch first then the cooler....
Hey paul , go here.
http://www.racetime.com.au/?event=h0318&e=...01&view=fastest
I cracked it on the last run 35.87.
Got 2nd still and Denver said I left 2 black lines from the rh turn all the way up to the finish. Hehehe
Cheers
Ken
paul - if ur asking me bout the dump - yea, definitely.. exhaust has a completely different sound and it's much stronger boost - doesn't fall off as much at higher revs.... i think that combined with the exhaust cam = good spool up... :(
    • This is actually a really good way of measuring what wheels fit. If only there was a similar measurement between hub face and suspension :p That said, it's probably pretty simple to actually measure it all with the wheel off the car for the rear. The front is a bit more complex but..
    • Being the top Google search result for R34 wheel-related inquiries, lemme throw down my experience. I calculated that 100mm from hub face to wheel face is about the perfect fitment for my ENR34 sedan.  I've been running 18x8.5s, ET35, with a 1" spacer. So, 8.5in to mm = 216mm. 216/2 = 108mm. 108-35 = 73mm. 73+ 25 (1" to mm) = 98mm.  If you wanna get close to this on dif widths, here are the offsets you'll want: 9" - ET around 15mm 9.5" - ET around 20mm 10" - you're crazy, but ET around 30mm All these should fit perfectly on a non-widebody, non-GTR Skyline. Note that it's probably the absolute max, and you're probably better off running a couple degrees of camber in this config, but it looks great, super flush.
    • Oh yeah, always always always turn over an engine by hand first.
    • So by that logic, an insanely expensive GTR for $200k+ is quite cheap, at 12% of Sydney's median house price compared to over 50% when a GTR was new...
    • Apologies... thought i had outlined it... Cheers for the response, I'll get a nipple sorted out for this.
