Originally posted by Nizmo
Ken where did u get the R's meshy floor mats from - Paul said u made them - hehe how much do they cost?
Yep made em , took me all day to drill 2 mats.
Bout 250 holes in each and every hole is a 3 step process.
To buy retail is around $250.
Have got a template of the hole spacing if you got the drill.
Cheers
Ken
  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
Originally posted by Kyles
I know niz.. its not fair... not relaly that many good looking blokes for us girlies on tv atm
Picky , picky
Any Blonde or redhead will do it for me....
Cheers
Ken
Originally posted by macka
Black beauty is winning (for a change)
White stallion a brave second......maybe
unless its stripped and sold to eastern states
Stripped and sold.
What's this , you in the midnight spares racket:D
Cheers
Ken
$250?? i think i'll save a little extra and go for the whole metal grid flooring for that!
Kyles - i know thers absolutely no male talent on TV *sigh* any we do get usually get sent over to England.
No prob , join the punched metal , holes don't line up when you cut it , same as every excel floormats.
I will stick with my custom fitted specifically designed and manufactured ones thankyou:D
Cheers
Ken
    • That is the option code, not the VIN
    • Apologies if I sounded like a arse My point was that you will not be able to buy a rotisserie that suits your car, you get the rotisserie frame, and then fabricate parts to mount the rotisserie frame to the body The rotisserie side is easy, but the fabrication of the actual mounts is the tricky part, where to mount so you don't bend/twist the body, plus the geometry involved to get it to turn  If your capable at fabrication, and can work out where the C/L is in relation to the weight is so it actually can turn, you should be sweet I would love to see the progress on this just for the thought processes and fabrication
    • Type "M2" means it's a series 2. I would not be shocked to learn that the production changeover was somewhat lax and a late 12/95 production car actually got mostly series 2 parts with a bit of series 1 leftover. Post the VIN and it'll be easier to investigate.
    • Yes, well, mine were 31 years old last year when they finally got done. Started to leak a bit.
