  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
Originally posted by Kyles
c) speak for your self mr! LOL
D) Females excepted ( mind you , doing it on the couch , rug , floor , shower , bed , table , verandah , car ... ) I suppose constitutes a limited life.:(
Cheers
jealous
Ken
Neo - we found one & I left the gate open for the other one as I spent around an hour walking the streets looking for the little bugger...he was waiting at the door when Paul got up at 5am.
btw - I saw you this arvo going up to PSI as you crossed over Wanneroo Road. I had already been there & as you would have found out they did not dyno cam's car today.
how do brownies work if you sit and watch telly??
Wouldnt work for troy.. he would loose em.. because it would be all geeky sifi crap
Means I'm in the same room. She is easily amused the One Who Must Be Obeyed
Cheers
brownie collecter
Ken
hey guess what? mums coming down in convoy with us in the lazer hehe.. she will probly beat us down there the hoon. Shes going to try and borrow a porche of a good friend of ours and borrow that.. pitty our friend with the lamb isnt in perth.. shes in albany.. damn. They used to have a helicopter too
gez it would be nice to be loaded
Make sure she doesn't pass Willy.
Hmm , it's hard NOT to pass Willy when he drives at 5 under the limit. Hehehehe
Cheers
Ken
    • Hi soviet_merlin, We appreciate your concern regarding this possibly being some sort of PR/Political hype, I assure you that is not the case, I wish we could claim something like that, but in this case, we merely reached out for comment on the basis of the outrage we too felt, as those heavily in the automotive industry. Ps. the original source in the social media post is CarExpert not CarExplore.    Best, CE.
    • Made a bit of a discovery, but while I was cruising, I randomly decided to test to see if it worked and it showed up on my IC7. The entire time I tested it before, I never thought to turn the ignition on. I only tested it with head lights turned on but with the ignition off. Huge oversight on my end. I’m a dummy. I know.
    • G'day all, I have drilled and tapped the hole for the relocation of the timing belt tensioner. That was straight forward. I'm unsure if I need to also put another hole for the smaller stud that the spring behind the tensioner catches on (this is how it seems to work in its original spot). Or do you not use the spring behind it and just torque it down? Thanks in advance, I did a search but couldn't find anything related and it doesn't mention it in the rb30det sau guide.
    • Hi All,  just thought I would provide an update as I know smooth (Matt) was on this forum from 2003.    my brother Matthew passed away end of may 2024 at the age of 41 from liver failure. I am not sure how many of his original team krazy friends are still on here or active but thought it reasonable to let the forum know.    if you have any photos or pictures it would be great if you could share them.    it took me a while to work out he was active on here.    thanks so much
