  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
ahh i'll go to xspeed, for the peace of mind that they'lldo a goodjob! anyways i am off boyz catcha later hopefully by tonight i can have my screamer pipe on, and yall can come check it out :P hehehehe as i got the next two days off :P heheh the peeps at work reckon i deserve a break :(
adrian :P
yeah im trying everything Paul - hmmm computer let me into chatrooms but not accomodation sites - go figure! Found htis one place mmmmm heaven but at $180 a night minium two nights stay it would want to be!! oh well when i win lotto :P
Originally posted by GTS-t VSPEC
Bayley, I was pissed off cause of the yellow sticker, so I took my aggression out:D
See'ya:burnout:
We were sitting there and then heard it and Jeff goes, that was Paul!!! I was like, what did he get a yellow for, bald tyres? What did you get it for?:shake:
oh u should see the furniture in it and spa and just everything its totally gorgeous - thing is id get there and never want to leave. pity one night.
shall keep searching..... when i can anyway!
I'm with you paul....had some pig attention last night..
minding my business pulling out of Dewsons shopping centre around 8:30pm (yes, it's open till 9pm) up the road, doing like under 50km/h (was having a conversation with the gf next to me)
coppers were stopped on the side of the road in thier paddy wagon, as soon as I passed them they started driving and followed me.
going thru a few roundabouts, sticking to limit i was fine, then i thought, nope. i'm sick of them tailling me so I pulled into the next service station and parked the car to get some munchies...
they followed me right up into the servo and watched me get out of the car and go inside.....
... i was pissed off! then they left.. there was NO call for them to be assholes... but no no, let's follow the IMPORT DRIVER and ignore the rattly shitbox that was next to me!!
ive only been tailed by a copper once - on a test drive of a skyline - otherwise its usually me tailing them :P
Im lucky that my rare brushes of law have been pleasant ones - prefer it to a multinova anyway - as one copper told me "im not a multinova so he began to bargin with me hehe"
    • Oh yeah forgot to also mention need to also unplug the IACV as well. Thanks for the reminder @MBS206 Unplugging the TPS takes it out of closed loop so you're able to screw down the IACV without the ECU trying to add/subtract timing to maintain the idle (not sure PowerFC can even do this, but Nistune and the OEM definitely does)
    • For sale is my 1999 Nissan Skyline R34 GT-T, tuned to 234 kW / 313 hp. I've had the car for a few years as my daily driver. The car is original (as far as Skylines go), with only a few minor upgrades to enhance performance and driving experience, as typical for such a car of its age. Overall, it is in great condition with no body rust, thanks to its earlier import date. It features a top-notch security system (not literally, but it's great!) with remote start and still functional 4-wheel steering via HICAS. It comes with several performance and handling upgrades, including:     Hypergear 450HP Turbocharger running 17 PSI boost, installed mid-2021 by Jaustech     550cc injectors     Nistune ECU     Front-Mount Return-Flow Intercooler     X-Force Stainless Steel Exhaust     Upgraded engine mounts     Bottom end bearings replaced     BC Coilovers     Lenso DR1 rims     Bridgestone Potenza Adrenalin RE003 TL 245/40R18 97W tires, fitted early 2023 The interior is mostly stock, with a few additions:     Viper Satellite Tracking System with remote start     Bluetooth Double-Din Touchscreen Head Unit     Steering wheel cover Cons:     A few paint imperfections here and there     Driver’s seat shows more wear than the others. It's not torn at all, but I've added a seat cover to protect its condition. I also have a CarVX Vehicle History report available for serious buyers, so you don’t need to purchase it yourself. Price: $26,000 ONO.
    • I've had two suzukis in the past have an extremely hard time turning over and not starting after sitting for a few weeks. Ended up the alternator would seize up causing the starter to force. Same issue both times.  Maybe they're sourcing their alternators from the same place...
    • Ah right. Maybe my rb just loves chewing through batteries lol.
    • On the R34 can't you just unplug the IACV? This is the way I've always done it on the R33. Disconnect IACV, get it idling around 650rpm, and then do a power reset on the ECU to get it to relearn idle (factory ECU).   The big reason no one has touched on as to why you'd want to get the base idle right, is that it means the computer needs to make smaller adjustments to get a good idle at 700-750rpm.   Also, cleaning the IACV won't normally make the car suddenly idle lower or higher. The main issue with the IACV gumming up is that the valve sticks. This means the inputs the ECU gives, aren't translating to changes in air flow. This can cause idle choppy ness as the ECU is now needing to give a lot of input to get movement, but then it moves too far, and then has to do the same in reverse, and it can mean the ECU can't catch stalls quickly either.
