  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
Originally posted by GTS-t VSPEC
Rob, but if you bought a $20K car and had a $6k rebuild then you'd be in a bit of a shock unless your prepared for it.
See'ya:burnout:
Pauls right ( amazingly ! ). Even the 92 on GTR's I bring in ocassionally have a few probs.
Any good 89 GTR under 100K these days will not be cheap.
Cheers
Ken
Rob , I am on geoffs site and have seen them all.
Yes it is cheap but that is relative. An 89 GTR is getting on . I have a 92 for sale for $28K with fruit and it is here.
I would be prepared to spend some money on a 89 GTR cos it will need a few things ( clutch , d/shaft boots , brake discs , top arm bushes etc )
Cheers
Ken
    • Stock ECU has compensation, you won't damage the engine. Personally I recommend getting an acceptable catalytic converter, it doesn't need to be OEM and super expensive but a cheap universal one to keep it from being super obnoxious to be around. Decatted cars smell pretty awful.
    • Correction. Ignition was on before, but I guess the car had to be running for it to work.
    • The stock ECU won't care. The gains from Nistuning the ECU and then "optimising" the fuel and ignition tables will be about 2 more HP.
    • Appreciate the feedback. It is street car, but not a daily. Last week I got a quote from a good exhaust shop for a decat, one which is bolt-on, bolt-off to be easily replaceable. I got quoted for around €150. I usually do push the motor, but I wasn't in this case to make sure that no damage is done until I get the cat sorted. I think it's best to also ask the exhaust shop for the other option and see what they can do. If (big if) I were to decat though, would it be best to tune the car or would the stock ECU handle it? As far as I know, the stock ECU is not tunable and that would require additional purchases.
    • As above, definitely bash it or get it replaced with a high flow unit.
