  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
Originally posted by rob77
I paid 550,000 yen for my r33. It was dead stock when it got here and was listed as a grade 4. Apart from 1 pin dent, which I think happened on the way here, it was a grade 4 car. Since then and a few australian carparks later its got 1 more pin dent, a paint scrape (that should polish out with a cut and polish) and a small dent in the drivers side door. I think I paid a pretty high price for a 94 dead stock car, but the condition is excellent.
Depends on the auction.
I looked at a supposed Grade 3.5 car for someone today and it had both 1/4's repainted and had a new beaver and repair to boot floor.
Jaa auctions are slack with there grading but USS are pretty good.
Cheers
Ken
Originally posted by GTS-t VSPEC
A new beaver? What the?
Cam, I'd do it again, but I'd make sure all the tools were there first:D
See'ya:burnout:
Rear tailight panel ( called a beaver by those who know..... )
Cheers
Ken
Originally posted by gtrken
Supposedly has 450hp atw but doesn't seem like it. Is the JUN engine but with a supercharger.
Engine was getting hot so AJ parked it. I would too knowing the cost of that motor.
430 odd at 6500, main problem is it was breaking down above 6500, seems to be either stuffed cam angle sensors(we took a spare, well swapped the one in the car on sat night hoping it would resolve the issue, but didn't, we never had time to test), or theres an issue with the motec not feeding it enough voltage, so the top end speed was reduced, as was using each gear to its peak potential..
we didn't make it there saturday as the car only first fired at 6:30 on saturday morning, and a couple of issues brough tuning to a halt early on saturday morning, wit the issues fixed aj tuned it sat night, well, tuned it to 6500 as it had the ignition issue above that, a few of us did a pile more work to it sat night to get it completely ready for sunday..
race one, the pivot starter switch jammed on, so after half a lap, rather than trash the os geiken flywheel and starter motor he pulled off and had it pulled back to the pits, replaced pivot switch with a normal push button switch found at the local dickies, fixed that problem, second race it had heat issues and rather than risk anything he pulled out, no need to push it, we wouldn't have won anything, and lost everything..
on its first ever lap it cut a 67 second lap, which is about 3 seconds off the front runners, not bad for a brand new car the owner hadn't driven more than 200 meters..
we'll be back at the next race with the issues addressed, and will hopefully be able to show the full potential of the car, it managed a 66 in race pace with traffic and was quickly catching the rx7 of kim ledger so we're happy, and the car looks and sounds awesome..
    • No need to drill any holes. There's plenty of access to reach through and behind all of that steel to "push" from behind with a pulling action on the slide hammer. There's all sorts of attachments you can screw on the end of them.
    • Yea the photos aren't the best. When I was pulling the bumper and headlights out there was a bodyshop guy looking on for it, there is a slight bend behind where the passenger headlight is, but we're talking a few MM and there is a little bit of a bend for the reo. That said it's supposedly well within the "Drill a hole in it and pull it out with a slide hammer to be close enough" and be on our way. The other option is to buy a GTR reo for the GTR bumper bits but this is a $2000+ fix for something Mr Hammer can probably do 99% of the job for and everything will/can line up pretty closely-to-good-enough.
    • That's a write off for sure... Part out? 馃槢 I kid. It looks like the rad support has a minor minor bend in it too where the rep support sits near. Could just be the photos (and me not wearing my glasses right now). Worst case is you can buy a new radiator support, have it swapped over, and leave the car in paint jail for 12 to 18 months while you build the motor to handle twin turbos or a Harrop SC...
    • It seems the definition of "Gregging" something might need to be expanded?
    • This is why I suggested that there is really nothing that can safely be done in the engine bay at this budget level. Just the work to reassure yourself that the engine won't instantly crap itself the moment the boost gets turned up will wear out the piggy bank long before the first turbo gets installed. Spend $10k and still not have any extra performance? My tip is a version of our standard advice from 15 years ago about buying a GTR, which is not to buy one unless you can afford to buy two. The new version is not to modify a GTR unless you have all the funds required to do it all at once, properly, and enough to rebuild it after it blows up.
