  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
rob:- the hks type s kit is on the taka kaira site for like 1600 delivered nengun gonna do it for $1300 :) so trust is more then likely exactly like yours :)
cam:- if ya wanna use original holes then ya probably better off getting trust kit i'm guessin we shall wait and see :D
off topic anyone wanna give me a day time job?
adrian :(
Paul
It wasnt the exhaust that was the problem on Sunday the limiter came into play on those straights.
Adrian
Yes i think brent is getting a Apexi contact. He is the one who is getting my exhaust in after i had problems with australian supplier.
Cam
Hope you got your socket set in the car now? No worries anytime.
adrian damn... are u selling drugs on the side? :) jk man
franks (r34) from NSW has the HKS kit not sure which model but his uses the stock piping too.. pics:
http://www.skylinesaustralia.com/forums/sh...5026#post105026
    • Too much work, but guess I will have to
    • qld plates “GTR R34” for sale $5500 (listed else where)
    • Or, just take PS pump off and inspect? Does no-one do this any more?
    • Yep it is overflowing. All was working fine but been off for a year so guess something may have seized. Steering is heavy yes   i will raise the front of the car and will turn side to side to test id bubble goes away
    • Does the steering feel heavy when you turn the wheels? Any puddles of fluid on the floor or that you can see leaking from anywhere? You could try bleeding the system, if it’s making a whining sound when turning the wheels then that’s a sure indication there’s air in there somewhere. Start the car and remove the reservoir cap, then turn the wheels from left to right a few cycles and then check if you see any air bubbles rising to the top of the reservoir. Top up if necessary and repeat. Otherwise, I can only suggest that your pump vanes have seized or that there is a perished seal somewhere??
