  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
Hey there russ, rob, ken, anyone else...
Ken - I got enough backlash in my rear diff that I should get it attended too. Had the car on a hoist at a local performance shop the other night to check it out. I was told that it was prolly something to do with a spacer type thingo (sorry cant remember exactly) that would need to be replaced inside the diff where the tailshaft connects. I think it is compliments of a lack of experience launching the car from the one time I went to the drags.
Anyway - to cut a long story short - can you tell me where to go?
Yep can do but your wife has already done it for me...
Is the diff noisy?
The spacer thingy is probably the crush washer for the pinion bearing.
My advice is to just turn up the radio a bit louder. Removing , o/hauling and while it's apart , replace the clutch packs , carrier bearings , reset the preload etc then the figure will be in the $1300- $1500 region.
Get a 2nd hand one and be ready to throw it in if you run out of radio volume.
Cheers
Ken
Originally posted by rob77
My driveshaft needed 3 new unijoints when it got here, they were all fubar'd and made the car vibrate. Place in osborne park machined them and replaced them for around $360 all up. Driveshaft Balancing I think the name was.
One of the few places I know is Diff and Trans in Jolimont.
Know a few tailshaft mobs but they are not diff rebuilders.
Cheers
Ken
Thanks guys.
Ken, there's no noise, & I think it was the crush washer that they were talking about. I wouldn't care about it except that I was told it could cause excessive wear on the crown wheel (I think that's what it's called).
But then again - drive it till it breaks then get one 2nd hand for around $500 bucks I reckon.
Originally posted by Micko
Thanks guys.
Zachary...
You one smart cookie boy:D
Cheers
Ken
Ken - I'm gonna check out Gav's mines ecu on sunday & will prolly be doing a deal with him. He reckons it gave him around 300rwhp on SST's dyno.
In conjunction with what.
Std they are around 200-220 hp at all 4 . Would be surprised if just a puter made that diff.
Cheers
Ken
Originally posted by 33Spec2
haha so true ken!:D where paul and aidwin these days? and they call themselves whores!!
Paul and Aidwin , both MIA.
ewww , that conjures up some horrible images.
No Niz either. Hmmm , a 3 some.....
Cheers
Ken
Let me know if you stumble across a diff in your travels Ken - if you see one for the right price it would be worth me buying for when either of us have a need for one :D
I gotta spare , it's in the ricer.:D
Actually ,C Red have a few for around the $800 mark and I think they may even have a 1.5 or 2 way.
Cheers
Ken
    • Oh, that's grim. Something bad has been happening there.
    • Put an endoscope down the hole and saw this. Not quite all around the bore but a good 60% at least. Chin to the chest and towards further disappointments I guess.
    • 2 does "sort of" applies, maybe......but looking at what parts would be needed for the swap to get engineered, registered, and insured, and basically that's everything under the car, the modifications the make it legal would be problematic and horrendously expensive, all for a street car that just cruises around and hits a few twisty roads on the weekends Also, from looking at the NSW rules and Regs, with all modifications that is required just to make the car safe and not twist itself to pieces, and then actually get registered for street use, may still be impossible nowadays As for 1, when you add in a fresh engine, fresh transmission, rear cradle and diff, tailshaft, suspension, brakes, cooling, and all the other fabrication required, your probably looking at up to $100k to do it right, all for a 20 year old MX5 that is over engineered and you would never be able to actually use the power it has on the street, much like your beastie, which I love, but you actually track that thing and can use all of its powers in anger, in a safe environment  Hell, the old Bogan Cruise Ship had more power than I could use on the street, and in hindsight, I went a bit silly on that thing, it didn't really need the 500hp it had for what I actually used the car for, it was fun, but basically unusable on the street if you value your licence  As for cams, yeah, I'll probably book it in for them to get installed and tuned soonish, like next month after MX5 Mania are back at work....... and yes, I've already sent a email to bin the turbo quote and quote instead to install cams and a new Fluidampr balancer that will suit the 2.5 better than the OEM 2.0 balancer that is swapped over for the 2.5 install, as the balancer needs to get pulled to time the cams it's a while your in there sort of thing I did think a bit about flex fuel for a laugh, but being na, and no where really around locally anymore to get E85, I've binned that idea, so no sweet sweet corn smells are set for the car I wish E85 was more of a standard fuel, it's better for the environment, better for tuning, plus that sweet sweet smell we all love As for fitting in the family, that's not needed, as everyone in the family already owns a car that can seat 5 humans comfortably enough, the MX5 is "my toy" As for buying a car that is already built, nah, I would rather pick and choose my parts, I enjoy the process, and in the big picture, the additional cost is well worth the enjoyment, and the occasional frustration, I get out of doing it, albeit with other people spinning the spanners, and me, just paying the invoice 🤣
    • Excuse me, but 2) does apply 1) Would also apply if you consider how much is spent in the alternatives. Also there's the option of 3), buy one pre-built that you can put your family in (it's me, it's my car)   That said, I went on a ~500km drive the other day. I didn't use anything more adventurous than 3rd/4th gear at about ~3000RPM and 50% throttle and I was going as fast as anyone has any sense doing on a public road, with enough grip to the point where I didn't want to go any faster. I was obviously under the limit of the current car etc etc. MX5 with 2.5 N/A to achieve the same speed would be more fun for any road scenario. Maybe consider cams. I wouldn't boost it. The use case is just not there and it won't actually make the car more enjoyable unless you really do plan on wringing gears from 1st to 3rd (at least) at 100% WOT on a public road to 150+kmh.
    • Great if: 1. You had all of the money for everything else that is required  2. Lived in a country where you could actually do this and drive it legally on the road Sadly, neither applies to me As for the turbo, I am having second thoughts, mainly for engineering/registration legality reasons and insurance  Not saying I've finished doing stupid things that I probably should do to the MX5, but boost, and V8 engine swaps isn't on the cards Strange, but true
